Silcone radiator hoses are porous, bad
Old Feb 9, 2009 | 04:28 PM
TimeMachine's Avatar
Bosozoomku
Thumbs up Silcone radiator hoses are porous, bad
Reading a report from Carquest (I don't know, either), it appears that silicone radiator hoses, i.e. Samco or other, are 15 times more water permeable than standard EPDM (rubber) hoses. Using these hoses in a regularly heat-cycled street car WILL result in water loss at a significat rate.
Anyone thinking of using silicone hoses for their radiator should consider this article: "New Technology Advances Cooling System Performance."
If you DO have silicone radiator hoses, check your coolant level!
Old Feb 9, 2009 | 04:46 PM
CosmoQuik's Avatar
busted in here eye
look at the date on the article it over ten yrs old that sir is out of date i have had samco hoses on the drag car for over 8 yrs and have never had any coolant loses and none on my other four cars i have put them on, if your going to research things make sure your info is up to date
Old Feb 9, 2009 | 05:46 PM
Bosozoomku
Just because information was discovered in the past doesn't make it irrelevant. The article is 10 years old, but the relevance isn't. Silcone hoses are still water permeable. Drag/race cars get maintained and prepped more often and differently than street cars. Do you have silicone hoses on a regularly driven street car?
Old Feb 9, 2009 | 06:01 PM
dradon03's Avatar
Derwin
Awkwardly enough:
http://beyondthedyno.com/Blogs/Eric/
Old Feb 9, 2009 | 06:03 PM
Bosozoomku
Originally Posted by dradon03
Lol, that's exactly what I read before I decided to post it over here! ...even though everyone should be reading that blog already
Old Feb 11, 2009 | 11:38 AM
CosmoQuik's Avatar
busted in here eye
well anyone who doesnt check the water on a regular basis is a moron anyway, lol 4 qts of water **** thats half empty, i do run silcone on two dd, very little if any water is add at oil changes and only throught the overflow bottle, level in radiator is always good, but my first response was more toward the fact that up-to-date info is more supportive in your post to other who may read it
Old Mar 1, 2009 | 12:02 PM
NoPis10's Avatar
Committee Member #2
I have them on my DD and no issues so far...
Thanks for the article ... good info to read...
L8R
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Frisky Arab
Sep 4, 2015 06:17 PM
