Evo-R Sleek Kit Question
Old Feb 3, 2009 | 09:23 PM
TT_Rotary's Avatar
Rotor Mech. Need'd 4 Mods
I bought the EVO-R's a while back, and just curious if any1 else who has them, has the same problem i do w/ the covering in the back, which is just a rubber piece that doesnt fully cover it.. is there a way to shut it completely in the back so that nothing gets in under your headlight covers? Or should i just tar the top of it and leave the bottom and sides open, that way there is some sort of protection in the back?
Old Feb 4, 2009 | 07:19 AM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
mine is open in the back, so i found a spider in there once, but i haven't had any real problems. the good thing about being open is that you don't have to worry about a perfect seal, and therefore no condensation fogging up the glass. this happens all the time on the g35 and 350z lights.
Old Jan 19, 2011 | 07:26 AM
Troux's Avatar
I would like to bump this for more opinions on sealing these. The rubber pieces I got are far from a perfect fit, so I was considering buying the same kind of rubber and making a good fit, with proper holes to seal the grommets, and double sided tape to seal the edges. The above post makes me wonder if I'd be better off leaving them open in the back, or maybe double-sided tape with a screen, to keep spiders and bugs out, but still prevent condensation.
Old Jan 19, 2011 | 07:35 AM
Laz93RX7's Avatar
All Hail the Magic Conch!
I have had mine for years and have them open never had a problem, if they start getting a little dusty inside I just get an air gun and blow it out. why do you have to have them sealed?
Old Jan 19, 2011 | 08:39 AM
Troux's Avatar
Usually to keep debris/bugs out, keep the bulbs and wires safe, keep water from getting in, etc. Not an easy part to wash if even a couple spots build up. I could also see them looking better with a black backing to darken them.
Old Jan 19, 2011 | 04:30 PM
Tai-Lun's Avatar
Re-build... again...
I used a bit of black silicone and braced the areas around the body while it dried, haven't had any issues.
Old Jan 19, 2011 | 06:04 PM
Troux's Avatar
Did you use the rubber that came with it? Mine doesn't quite fit...
Old Jan 19, 2011 | 11:09 PM
fd3s777's Avatar
Registered User
L/R are different. Make sure you have them right. On my FD I did not put the cover on also.
Old Jan 22, 2011 | 07:42 PM
Troux's Avatar
Trust me, I thought of that. They don't fit the headlights, neither did the brackets provided, neither did the hardware provided.
It seems like they will hold themselves up fairly well on the wires alone (hold the rubber between the provided wire grommet and the lights themselves). I think I'll just do that, to allow access into the lights later, if needed.
