Another boost problem
Old May 21, 2002 | 05:55 PM
Rx-7$4$me's Avatar
Hey all. Got a secondary boost problem here in my FD. Under WOT primary gives me a lil over 10psi. When secondary kicks in at 4500 it drops to around 8 then slowley drops and ends up at 5psi right at redline. vacuum is 18ish during idle. I checked both Y-pipe couplings, and the intercooler to y-pipe has two small cracks in it that didnt look like they went through, and Im still stock other then intake. I removed the Air tank, and it sounded like it was hissing air out when I put my ear next to it, and I looked under the upper intake manifold and I couldnt see any popped off lines ( I didnt remove it, just looked through the opening that the air tank covers up). What should I try now? 71xxx miles on original engine and turbo.s
Thanks alot
STevo
Old May 21, 2002 | 06:06 PM
mjw's Avatar
mjw
Your answer is already in your question, imagine that cracked pipe trying to hold in pressurized hot air.. that is your problem, I'll bet they go through.
Matt
Old May 21, 2002 | 06:18 PM
Rx-7$4$me's Avatar
well, it didnt seem like it, but im def gonna try that out
if its not that. could It be my precat is clogged?
what else should I check?
Old May 21, 2002 | 06:24 PM
serge1's Avatar
hey
Do the silicone hose jobs and that will illiminate
many, many boost problem. The job is a big pain
in the *** but it worth the effort.
Serge
Old May 21, 2002 | 09:26 PM
Rx-7$4$me's Avatar
BUMPITY BUMP!
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
tiger18
Sep 3, 2015 08:27 PM
