Steam Cleaning Engine via UIM
Old 01-25-09, 10:12 PM
boosted94's Avatar
Question Steam Cleaning Engine via UIM
I would like to clean the carbon build up in my engine and would like to know if this procedure is right. Take a gallon jug of distilled water, connect a vacuum line from the extra nipple on the UIM to the jug. Now do I have to keep this line pinched a bit or can I just let the engine vacuum take the water freely while I rev the engine to about 4k to keep it from stalling. Another other advice would be greatly appreciated.
Old 01-25-09, 10:16 PM
Rx72Heaven's Avatar
http://www.rotaryresurrection.com/2n...injection.html
Old 01-25-09, 10:40 PM
boosted94's Avatar
Which are this two nipples as mentioned in Rotary Resurection. Can someone post a pic. "Some engines (fd’s and s5 na’s for example) have 2 separate nipples that can be teed together externally (vacuum hose and tee) to evenly feed both rotors."
Old 01-25-09, 10:42 PM
BC-FD3S's Avatar
just do one gallon per rotor. one rotor at a time.
I did this an had a 5psi jump in my compression. still holding strong.
Old 01-25-09, 10:43 PM
Rx72Heaven's Avatar
I believe these are the 2 nipples on the side of the UIM before it connects to the LIM. One is used as a boost source for your gauge.
id go outside and take a pic, but its like -30 here. BURR.
Old 01-25-09, 10:44 PM
Rx72Heaven's Avatar
yea, did that stay? like the jump in compression? or did it taper off and go back to the previous compression #'s?
Old 01-25-09, 10:45 PM
BC-FD3S's Avatar
nope, it's still the same. hasn't dropped yet.
Old 01-25-09, 10:46 PM
Rx72Heaven's Avatar
wow that's impressive. How many KM on your build?
Old 01-25-09, 10:56 PM
boosted94's Avatar
so I tee the two nipples on the UIM? There's no problem running the car without the blowoff valve connected and revving up to 4k.
Old 01-26-09, 12:33 AM
BC-FD3S's Avatar
no problem
Old 01-26-09, 12:47 PM
apeiron
rev the **** out of the car, having a buddy there to help you is always nice too
Old 01-26-09, 02:33 PM
BC-FD3S's Avatar
or you can rev it VIA the throttle body like i did. wear gloves though.
Old 01-26-09, 02:35 PM
I'd recommend revving the motor to about 3000-3500 rpm.
Old 01-26-09, 04:37 PM
Urban Combat Vet
Sgtblue's Avatar
You might also keep an eye on your downpipe and make sure it's not getting anything too hot.
Old 01-26-09, 08:34 PM
Rx72Heaven's Avatar
Why would it? just curious.
Water into the combustion chamber should cool down the EGT's. And its not that long of a process either.
Old 01-27-09, 05:32 AM
Urban Combat Vet
Sgtblue's Avatar
-----> https://www.rx7club.com/showthread.p...threadid=42318
Old 01-29-09, 02:42 PM
shifterkartracer's Avatar
I just wanted to know how often you guys "steam clean" your motors. I plan on doing that this weekend and I just wanted to know the mileage intervals on cleaning it.
Great Info
Thanks!
Old 01-29-09, 04:46 PM
Don't worry be happy...
Montego's Avatar
interesting thread... in to keep an eye on it
Old 01-29-09, 08:14 PM
Mr Sparkles
Chadwick's Avatar
I use Seafoam http://www.seafoamsales.com/motorTuneUpConsumer.htm then follow it up with water. I do it around once a year.
Dan
Old 01-29-09, 10:00 PM
Now that I think about it my motor is about due for some steam cleaning.
Years ago when I was part-owner of Gotham we had a customer deployed to Iraq and we were storing his FD. All the months of starting his car to move it outside and shut it down caused a side seal to stick (90k original motor) and the steam cleaning caused the problem to clear up
Old 01-30-09, 02:18 AM
DAMN!Nice
Wo:Deep's Avatar
Hey Boosted94:
When you´ll do it,
why don´t you take some pictures and make a video.
Then you could make a little easy to understand how-to for everyone!
REgards
Marc
Old 01-30-09, 08:30 AM
ptrhahn's Avatar
Excellent, a new flight of maintenance to perform. I was getting bored.
Old 01-30-09, 09:24 AM
wickedywick's Avatar
you too, knock on wood
Old 01-30-09, 01:11 PM
500+hp club
silverfdturbo6port's Avatar
i have done this for years on my own and customers cars but only recently did i relize that your shaving some life off your housings by washing down the oil coating and metal on metal is in more contact. anless you run premix i probably would not recommend. i steamed a block before a rebuild and eveything was bone dry no oil or anything when i tore it down so just keep it in mind
Old 01-30-09, 05:13 PM
Would you then suggest running a premix, drive around for miles, then steamclean?
or run a premix after?
Thanks!
Quick Reply: Steam Cleaning Engine via UIM
