rx7 intake , exhaust: tunning?
Old Jan 23, 2009 | 01:38 AM
BlackWolf's Avatar
CA rx7 intake , exhaust: tunning?
I've heard that if you modify your intake system (cold air intake) and exhaust (header, cat and mufflers) that you have to tune your car in order for these mods to perform or else your motor ***** up?? is this true? i've had a 240 and it had no problems changing out intake, header/exhuast, but im new at rotary. So ive been asking more ppl but no one really gives me an exact answer.
Old Jan 24, 2009 | 10:15 AM
dgeesaman's Avatar
This idea comes from turbocharged rotaries. If you have an NA car, don't worry about it.
Turbo'd rotaries cannot tolerate lean AFRs under heavy load. When you add mods on a car with stock boost control, boost levels increase and AFRs get leaner. The old school way of thinking was to keep count of the number of flow mods so that yo don't create a setup that's going to elevate the boost too much. The more modern approach is to use a boost gauge and boost controller to keep boost where it needs to be according to your setup.
Old Jan 24, 2009 | 03:24 PM
trochoid's Avatar
Old Fart Young at Heart
Since your profile lists a 90 NA, adding headers, which won't pass CARB, and a CAI would be the first and best step to increase hp/performance. These 2 mods are safe without any other adjustments needed.
Old Jan 25, 2009 | 01:55 PM
BlackWolf's Avatar
Smile
ohh i see. yeah I understand about the turbo set up. I just didn;t know if it applied to all rx7s even if they were NA. thanks guys!
Old Jan 26, 2009 | 05:54 AM
waterboy222's Avatar
waterboy222
hey thats helpful
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
