Brake Master Cylinder replacement
Old Jan 22, 2009 | 05:12 PM
Boyztoyz's Avatar
Newbie
KS Brake Master Cylinder replacement
What's the best (and easiest) way to replace the brake master cylinder. I have brake fluid leaking from between the reservoir and the metal housing. I bought a new brake master cylinder and would like how to advise from someone who has done it.
Old Jan 22, 2009 | 11:03 PM
Icemark's Avatar
If it is just leaking at the bushings between the cyl an dthe tank, just replace the bushings.
No sense spending money on a new master cyl when $15 worth of parts will fix the problem.
Old Jan 22, 2009 | 11:49 PM
trochoid's Avatar
Old Fart Young at Heart
Make sure it's the bushing that are at fault. I've seen the reservoirs crack. I'm just north of you in St Joseph and have spares if needed. Or you can check with Black Dragon, they're part of LMC in Lenexa.
www.BlackDragonAuto.com Sign up for thier catalog.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
