Power FC base map needed for stock fc3s
Old Jan 22, 2009 | 12:31 PM
KrisD1's Avatar
Hi, does anyone have a basemap for a stock fc3s series 5, or the basemap that comes with the power fc from ap engineering. Thanks.
Old Jan 27, 2009 | 10:58 AM
Ranzo's Avatar
Just go on the commander and use the initialize function and that will reset it to the base map.
Old Jan 27, 2009 | 12:30 PM
KrisD1's Avatar
Thanks razo, but I already knew that. I have a power fc from an fd3s, they are setup for 550 primary and 850 secundary. Need one for 550 secundary.
Old Jan 27, 2009 | 02:49 PM
Ranzo's Avatar
Hmm they really arent that different as far as the maps go. If you want I can initialize mine and send you the dat file.
Old Jan 28, 2009 | 07:23 AM
Banzai-Racing's Avatar
Rotary Specialists
What MAP sensor do you have? Is this our installation kit or something else? We would have emailed you a base map for your injector sizing. You can just go in to the injector screen and change the secondaries to 550cc.
Old Jan 28, 2009 | 12:08 PM
KrisD1's Avatar
Yep, it's your kit. Just wondering how the map looks on the ap engineering power fc's. So I just have to change the secundaries to 550cc. Thanks. Will the map I got from you be OK to run into boost on a stock setup?
Old Jan 28, 2009 | 01:42 PM
Rotary Specialists
You always need to verify AFR's. Far too many variables come into play to say that a map is going to be good in boost...octane, fuel flow, engine age etc ......
Just like it says in the product description: We will supply a base map, allowing you to safely start your car and drive to your tuner. The map will be set up with a basic program to suit your engine set-up per your supplied parameters. However, this is only a basic map and as with all engine management systems, additional tuning will be necessary due to the fact that all engines are different.
Old Jan 28, 2009 | 02:02 PM
KrisD1's Avatar
ok, thanks. I'm using an S7 power fc btw with the adapter harness from knightsports to the banzai harness. Will see this weekend if it works.
Old Jan 28, 2009 | 07:09 PM
Rotary Specialists
That is a lot of adapter harnesses in a row
astrum
24
Nov 15, 2017 08:44 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
