Hub/wheel bore interference?
Old Jan 22, 2009 | 07:08 AM
ColumbusTurboTwo's Avatar
IN Hub/wheel bore interference?
So I just got my Stern ST-8's in the mail. They look great. But there is a problem. The front wheels don't sit flushon the hub. The reason being that the wheel center has two bores. The main bore closest to the hub, and then a secondary (smaller) bore, which is for the center cap. Due to the long hub bore of the RX-7 the chamfer of the 2nd bore doesn't allow it to sit flush. Has anyone run into this problem before? is the best solution to buy a spacer? I tried using washers last night and I think a 3 - 5mm spacer might correct it. Has anyone done anything else to fix this? Grind down the lip on the car's hub? have the wheel's hub machined out?
Thanks!
Old Feb 1, 2009 | 10:12 PM
Halfbridge's Avatar
Brap Brap Brap
Well you could run a spacer just rember to keep checking the torque on the lugs. Spacers never keep the same thickness. The srink and expand all the time causing the lugs to loosen. And never grind down the hub on a car. your best bet is to have the wheels machined to a larger bore.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
angel824
Mar 17, 2019 09:44 AM
toplessFC3Sman
Mar 20, 2018 01:54 PM
Zinraf
Oct 1, 2015 01:09 PM
BLK 93
Sep 28, 2015 01:45 PM
