Turbo Oil Return Drain
Old Jan 20, 2009 | 06:41 PM
chiquirx7's Avatar
See you l@@king?
CT Turbo Oil Return Drain
turbo oil return line how big does it have to be for the turbo to discharge of oil
Old Jan 20, 2009 | 06:46 PM
DriftDreamzSS's Avatar
I use -10
Old Jan 20, 2009 | 08:23 PM
Smitter's Avatar
94 Single Turbo FD
i use -10 aswell, do some searching and u will find that some say -8 is sufficient
Old Jan 20, 2009 | 08:28 PM
mono4lamar's Avatar
In the burnout box...
Use at least 10an. I would really look at what turbo your running. Garrett ball bearing turbos require a very small amount of oil so the return line is less likely to become a "restriction." The journal bearing turbos use a bit of oil so the line sizing then is crucial.
Old Jan 21, 2009 | 07:24 AM
Zero R's Avatar
Just in time to die
Depending on turbo size and type .5" to .625" -8 or -10
Old Jan 21, 2009 | 02:18 PM
coolmike711's Avatar
What about oil pressure to the Garrett turbo. Is stock oil pressure to the journal bearing turbos ok or do you need a restrictor. I hear you do need a restrictor for the ball bearing turbos.
Old Jan 21, 2009 | 03:25 PM
chiquirx7's Avatar
See you l@@king?
thanks guys for the info
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
