water and seafoam carbon reduction
Old Jan 19, 2009 | 06:21 PM
dmolchanoff's Avatar
Is That A 4 Rotor?...
ok ive been reading alot about this but still not clear yet...i was wondering how much water do you use and how much seafoam do you use if you want to clean the rotor housings....i heard a liter of water and use one of the vacuum lines on the intake manifold...but how much seafoam do u use the whole bottle? and how long should this take should i suck up all the sea foam first and then all the water should i suck the water up and take a break suck some more and take another break so on .... some one please help i dont want to hurt the motor or foul out any plugs...
Old Jan 19, 2009 | 08:26 PM
IanS's Avatar
Ricer
Best way Ive found is to dump some seafoam into the spark plug holes and let it sit overnight. Then crank engine over by hand (its not hard) then start it up and let the engine clear out. It'll smoke like hell so dont do it in your garage lol. Next, put remaining seafoam into gas tank and drive around normally. I havent done the water thing only seafom so can only help with that.
Old Jan 20, 2009 | 12:34 PM
thanks alot yea it deff did work i put some in the plug holes last night and this morning cranked it started it up and deff smoked a bit for about a min...
Shainiac
Jul 17, 2019 02:20 PM
