electric fan install questions
Old Jan 19, 2009 | 03:39 PM
MIDWESTSTYLE's Avatar
i was wonder which wire to connect the ignition to on my aftermarket fan switch?? there is a wire thats supposed to go to the vehicle ignition wire. is there one under the hood i can use?? or do i need to go to the actual key and lock cylinder and splice it off of that????
thanks,
Brandon
Old Jan 19, 2009 | 09:00 PM
farberio's Avatar
NASA-MW ST4
By ignition do you mean a switched 12V line?
There should be one in the engine bay. Find a factory wiring diagram and it will reveal all the answers.
You can get one at www.rx7city.com
Old Jan 20, 2009 | 12:27 AM
smrtmark's Avatar
i just bought an electric fan for my 85 rx7 but i dont know if its the right one or if i need another part, like a mounting rack or something
Old Jan 20, 2009 | 09:04 AM
rxtasy3's Avatar
u'll need a relay also. instructions saying to connect a wire to ignition is alittle misleading. it really means a switched 12v source(key in the run position, not accessory), which can be easily found in the fuse box.
smrtmark, alot of electric fans r never a direct bolt in. u'll need to create some sort of way to mount the fan, whether u use those ties that go thru the fins of the rad or fab so sheet metal to mount the fan with. if u search my ID u'll find pix of the setup i'm using. my fan is from a '93 mitz galant. i'm using an rx4 rad so i just fab'd up some pieces of sheet metal to utilize the original rx4 fan shroud mounting points for the electric fan.
Old Jan 20, 2009 | 09:25 AM
Aaron Cake's Avatar
Engine, Not Motor
http://www.aaroncake.net/rx-7/efaninstall.htm
Old Jan 20, 2009 | 09:55 AM
so i can use the same fuse that goes for the radio????
Old Jan 20, 2009 | 10:06 AM
rxtasy3's Avatar
i use a 20 or 30 amp circuit. the relay takes most of the amp draw.
Old Jan 20, 2009 | 10:56 AM
Aaron Cake's Avatar
Engine, Not Motor
You're going to activate the fan with a switch? Not a good idea. Read the link I posted.
But if you really want to use a switch, don't use the ACC line on the radio. Use a constant 12V line. Wiring diagrams are in the FAQ.
Old Jan 20, 2009 | 10:29 PM
its an adjustable fan switch that i bought from my work....its set to turn the fans on at 160 degrees...one wire i need to go to ignition signal....
Th0m4s
Feb 26, 2019 02:04 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
