ECU Installation
Old Jan 17, 2009 | 07:19 PM
kevinflorimon's Avatar
ECU Installation
hey guys im almost done wit my n/a to turbo conversion. i have a 91 rx7. i installed the engine and transmission. all i need to the wiring and ecu. im kinda confused and diddent want to mess anything up. i was wonderin if anyone had experience doing this and knows what plugs into what? im new to this forum. thanks
Old Jan 18, 2009 | 11:16 AM
Icemark's Avatar
if you are putting in a S5 Turbo and S5 Turbo engine harness into a S5 non turbo car, it should all be plug and play.
Old Jan 18, 2009 | 04:47 PM
rx7forever22's Avatar
What are you trying to do? Wire in a stock computer or aftermarket ECU. I would wire in a aftrermarket ECU. Like a haltech or mircotech. If you plan on performing futer mods you can tune for them.
Old Jan 19, 2009 | 11:17 AM
thanks guys. im trying to just install the stock turbo ecu. If i mix and match the wrong plugs will it fry the computer? or will it just not start? im planning to stay wit this one then, later upgrade to a better ecu...
Old Jan 19, 2009 | 11:44 AM
Icemark's Avatar
They can't be mixed up, they all only fit one spot
Queppa
Nov 18, 2024 03:47 AM
C. Ludwig
Jan 30, 2019 06:31 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
