Haltech E6S Users - Please READ! What you need to know!
Old Jan 13, 2009 | 07:19 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Hello all, i was bored tonight, so here's some of the things in my head when i get bored and theres too much caffeine in my system. Its come to my attention that amazingly enough there are still plenty of E6S' out there still. Some of you might need some info on this particular model of ECU, mainly because it does fall a little short of its later versions, the E6K/X.
First thing you should know is that even though the ECU is mainly intended to process crank/cam signals in Hall Effect form, it can read internal reluctors. But! unlike the K and X, to change these settings to suit your particular sensors you need to move some jumpers and dip switches inside the ECU. I wont go into these details since this is explained in the E6S manual in good enough detail.
Second, the E6S could not fire regular OEM (constant charge) igniters, it could only control "smart" (constant duty) igniters, Bosch's 008 module, or most MSD and CDI boxes.
Third, the E6S did not have the PWM outputs that the K and X have, and if you swap your E6S ECU to one of these the harness doesnt have these wires so you would have to add these pins and run these extra wires separate. In contrast, if you are still using an E6S and need a brand new harness, you can purchase an E6X harness from you local haltech dealer and follow THESE INSTRUCTIONS in order to modify your X harness to suit the E6S. Also review THESE INSTRUCTIONS FOR DOS BOX to get DOS programs to work with XP or Vista machines. And finally, here on YOU TUBE you can find instructions on setting up USB to Serial adapters for both DOSBox with Vista, or normal XP and Vista machines with HalwinX.
Fouth, the E6S unit had an 8bit processor which was placed on a socket inside the ECU which if shaken too violently might come loose and cause the ECU to not work or work erratically. Also, the overall clock speed of the processor, which enough for most applications could sometimes be slightly taxed under certain conditions.
Fifth, the E6S ECU normally had 2 versions, E6S and E6S-8, if you have a -8 this just meant that you could control up to 8 low imp. injectors instead of 4. If you have high impedance injectors then you can run 8 with no problems. You could turn a regular E6S into a -8 by moving some more jumpers inside the ECU, again, this is detailed in the manual.
Sixth, finally, another suggestion i have for you E6S owners is that you also read the E6K manual, its much more informative in general aspects of how Haltech ECUs of that era work, but of course, the S manual has the specifics of the S and its inner working. Pay close attention in the manual to the section on the internal jumpers and dip switches that need to be set correctly in order for the ECU to work with your particular application. In most cases it can be made to work but sometimes will require changing some of those settings around as well as incorporating other hardware to make things work better.
In the end, you would probably be better of updating to a more modern ECU like the E8 or even the E6X which is more capable than the good 'ol E6S was.
It can do the job right, just be patient and ask the right questions.
Hope this helps. Enjoy!
Old Jan 13, 2009 | 07:43 PM
crispeed's Avatar
'Tuna'
You must be really bored or something!
The e6s is like what? 15yrs old allready!
You need to find yourself a chica soon before you come up with something else new!
I know what's next. Using the chip from the game boy for datalogging!
Old Jan 13, 2009 | 08:28 PM
C. Ludwig's Avatar
www.lms-efi.com
Old Jan 14, 2009 | 10:00 AM
EFI Tech Wannabe
I said i was bored and had too much caffeine in my system didnt i?
Anyway, its amazing to see all these E6S still running around, but then again, there are still F3 being used today so, who are we to judge!
Old Jan 14, 2009 | 10:35 AM
BDC's Avatar
BDC
BDC Motorsports
Thanks for posting this, Claudio. I've been wanting to take a closer look at the DOSBox option as I'm considering upgrading to a newer laptop that may be using a new version of Windows. I'm still using Win98 just for the use of the older Haltech DOS software.
B
Old Jan 14, 2009 | 10:37 AM
C. Ludwig's Avatar
www.lms-efi.com
As soon as we get Vista figured out it appears MS is dumping it altogether for an all new OS. What surprises will it bring?
Old Jan 14, 2009 | 03:05 PM
EFI Tech Wannabe
Maybe it will be even worst, who knows, and we'll all need 128bit machines to run it properly, 10gig of ram, with 1ghz processor video cards with 1gig of video memory and 1 terabyte of storage to fit it all.
jdayau
Nov 29, 2019 12:11 AM
ZacMan
Sep 19, 2015 09:20 PM
doritoloco
Sep 5, 2015 12:41 PM
