Want Horsepower
Old Jan 12, 2009 | 11:50 PM
RBRotary's Avatar
CA Want Horsepower
Ok so I have a 1988 TII. it has 81k on it and the motor seems to run great. (except it needs a new fuel pump since its bogging) so i seriously want some good horsepower. I've really put thought of throwing a twin turbo engine in there and i'm not sure if thats the right step. I think that would make a great combo since its lots of horsepower with no weight. so far i've only done 3 inch straight pipe all the way to the turbo, HKS BOV, NGK spark plugs and spark plug wires and that's pretty much it. but i want some great horsepower gains. i'm part of this little friends group and i want to be able to beat all of them. (300z NA supra MK3 NA 240sx NA) they all think i have the slowest car but i'm sure i don't and i wanna throw it in their faces.. so i want to make some big changes
Help would be greatly appreciated
oh and keep in mind, i'm only 16 haha but i find my way to money.
Old Jan 13, 2009 | 01:45 PM
IanS's Avatar
Ricer
With your turbo back exhaust you ARE running at least some sort of piggyback for your ECU right?
Old Jan 13, 2009 | 08:19 PM
TheAbsence's Avatar
s4 Pride
The only contender in the above cars you listed (300z NA supra MK3 NA 240sx NA) should be the 300Z, correct? The Supra should have a little over 200hp, but tons of weight. The 240sx should be light but has no guts. Unless those are modded at all, you and your turboback exhaust should do just fine in keeping up at least.
Old Jan 13, 2009 | 10:26 PM
armando santiago's Avatar
NJ
theabsence is rigth u should be able to handle these guys but if u want more power do a turbo upgrade and a little porting wont hurt
Old Jan 13, 2009 | 11:19 PM
RBRotary's Avatar
nope no piggyback. should i be? and thanks :] i've always wanted to do porting but i heard from some sources that it'll come out to about 2800 for it. is that about right? thanks for help again guys keep coming with those suggestions and help please
Old Jan 13, 2009 | 11:21 PM
TheAbsence's Avatar
s4 Pride
The price for that porting job looks right, assuming you go ahead and throw in new seals and springs (rebuild kit) while you have the engine apart. I paid about $3,400 for mine, but I also tossed in silicon vacuum lines, new oil lines, etc. that drove up the price a little.
Old Jan 13, 2009 | 11:24 PM
RBRotary's Avatar
thanks for the info. hey theabsence you wouldn't happen to go to tab tuesdays in west covina would you? i'm always their. and your near by. i'm in montclair. oh and i've been having problems with my idle. not that big of a deal. i idle at 600 but when i start it up cold. the rpms go up and down.
Old Jan 13, 2009 | 11:25 PM
TheAbsence's Avatar
s4 Pride
Tab Tuesdays? No I don't, I don't even know what that is. But oddly, I am in West Covina all the time. A 600rpm idle is great. How bad does your idle fluctuate when its cold?
Old Jan 13, 2009 | 11:29 PM
RBRotary's Avatar
you should check it out. every tuesday starting at around 8 everyone shows up. give me a pm if your interested. well it starts and goes up to about 3000 then comes down to about 1800 then goes up in down from 1800 to 1900. sorry if i'm a bit confusing
Old Jan 13, 2009 | 11:32 PM
TheAbsence's Avatar
s4 Pride
Sounds to me like the accelerated warm up. RX-7s are supposed to do that when they're cold, and as they warm up, drop down to a more "normal idle".
Old Jan 13, 2009 | 11:34 PM
RBRotary's Avatar
but it keeps it consistent. and it sounds nasty. doesn't sound right at all. but it leaves when i drive it for a little.
Old Jan 17, 2009 | 04:37 PM
emdog16's Avatar
Emdog
More Power!!!
Hey man another thing you could b looking into would be a methenol injection Kit. You can get em from AEM on e-bay fo roughly 500 bucks. My friend with a TII car ran it and it allowed hi to rum more boost. It also allows you to get the kind of performance out of pump gs as if u where runing high octane. The meth also reduces intake and exhaust gas temps. It is a really good upgrade and it doesnt cost too much ither... Here is som reading info on the AEM site: http://www.aempower.com/ViewCategory...CategoryID=120
Good luck with trying to beat ur pals, sunds like a good race!!!
Old Jan 17, 2009 | 04:39 PM
emdog16's Avatar
Emdog
More Power!!!
Sorry i forgot to include in my prev. post, an FMIC would help a bit and also if you dont have a huge cash flow, possibly look into rebuilding your stock turbo as opposed to changing it.
Old Jan 17, 2009 | 05:44 PM
TheAbsence's Avatar
s4 Pride
EMS + tune
And ALL supporting mods. If you're gonna do it, you gotta jump in with both feet.
Old Jan 17, 2009 | 05:49 PM
emdog16's Avatar
Emdog
Red face
Absolutely. There are a ton of things you can do. Also i didnt notice you said you wanted alot of HP, if you know someone who knows how, you could look into getting say a megasquirt or even if you are really ambitious you could go full standalone. The possiblity's are endless it all depends on money time and effort.
Old Jan 17, 2009 | 09:48 PM
Crazyboostin's Avatar
SAFC, FMIC, equal length tubular turbo manifold, MSD ignition, high flow intake manifold, bigger injectors, bigger turbo.... just to name a few.
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
gabescanlon
V-8 Powered RX-7's
47
Mar 21, 2016 12:45 PM
doritoloco
Sep 5, 2015 12:41 PM
