More backfire than normal?
Old May 20, 2002 | 02:01 PM
93TTRX7's Avatar
I have an N1 and an HKS downpipe and I seem to be getting a lot of backfiring. I get most of the backfiring at low RPM like 2k or 1.5k...and I get the strong ones sometimes at high RPM when I quick shift gears. Should it be running this rich?
Old May 20, 2002 | 02:20 PM
From: Minnesota, now in FL and I dont think I'm goin back
When I went from totally stock exhaust setup, to a full straight exhaust I also noticed a lot more backfiring. I dont get much in low RPM's but I get some loud ones up high. Is this normal? Sorry I couldnt help. Im thinking maybe I am running a little to rich.
Old May 20, 2002 | 02:31 PM
Mahjik's Avatar
Mr. Links
Have you had the catback and downpipe on for a while and the backfiring has gotten worse, or are you just now noticing the backfiring after the install of those items?
I notice that my car will backfire quite a bit until it warms up. After that, it usually only backfires when decelerating.
Also, when was the last time you changed your spark plugs?
Old May 20, 2002 | 03:56 PM
I just installed my whole exhaust setup I havent even really drove it Im still installing stuff. You think the Spark plugs could be doing it?
Mike
Old May 20, 2002 | 06:24 PM
93TTRX7's Avatar
Spark Plugs were changed about 5k miles ago. The Backfiring happens on deceleration on mine too, the only time it does it in acceleration is at high RPM when I shift.
Also I had a bit of backfiring with the stock exhaust, but not much. It's noticably more with the exhaust (although maybe I could just hear it better)
Could it be a sign of a bad o2 sensor?
Old May 20, 2002 | 06:31 PM
Mahjik's Avatar
Mr. Links
Sounds normal.
You'll get quite a bit more backfiring after removing the pre-cat.
Old May 20, 2002 | 09:31 PM
JBC's Avatar
JBC
The backfiring is normal. Not all of the exhaust gases are not getting combusted due to the lack the precat. My car does the same thing and I get alot of carbon buildup in the tailpipe. I only backfire under deceleration.
Imagine if you had a midpipe---->you would be shooting fireballs!
Old May 20, 2002 | 10:52 PM
I have a MP and I shoot flames too but also backfires quite a bit. But it sounds like this is normal, thats what I thought. I still think I could take out a little fuel though.
Old May 21, 2002 | 03:03 AM
KINETIK_FD3S's Avatar
almost done
post some fireball video clips
Einheri
Oct 7, 2015 12:23 PM
binz
Oct 2, 2015 03:52 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
