whats the max power for a 13bTT
Old Jan 10, 2009 | 04:58 PM
RalliartEvoIX's Avatar
whats the max power for a 13bTT before it breaks and what kind of port would be good for a dd/moderate track use
Old Jan 11, 2009 | 10:12 AM
Aaron Cake's Avatar
Engine, Not Motor
Power before it breaks? 160HP or 200HP, depending on the year of your car...
Seriously though, I don't understand the question. Engines break at stock (and below) power levels, they break when modified.
Then key when modifying ANY engine is to do it correctly. For the rotary, that means proper engine and heat management. If you want a powerful and all around reliable 13B that will result in a fast car, then 400HP will do the job (either at the wheels or the engine).
A street port is probably the best bet for primarily daily driven use.
Old Jan 11, 2009 | 12:55 PM
rxerFC's Avatar
I heard that 13btt engines have stock 225hp????
C. Ludwig
Jan 30, 2019 06:31 AM
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
rx7shirley
Sep 2, 2015 02:11 PM
Alan777
Aug 13, 2015 02:47 AM
