TID Question
Old May 20, 2002 | 10:17 AM
TurboMike's Avatar
TID Question
I just did the TID mod yesterday, however ive run into a few problems. I read that the line that i pulled off the stock TID is some kind of crankcase ventilation, i capped it off with a vacuum plug and now it seems like the car has a huge vacuum leak (WTF??). I dunno, im gonna try to make it to the autoparts store and pick up a checkvalve (the old one barely works anyway), I assume i can just open atomosphere vent this thing??
Old May 20, 2002 | 10:56 AM
vosko's Avatar
Just Call Me Terminator!
i don't remember if i told you but there is a NJ bbq on june 16th. www.turbovr6.net for details
Old May 20, 2002 | 11:12 AM
j9fd3s's Avatar
Community Builder
i think you can clean the old check valve out, it can be vented to the open air.
mike
Old May 20, 2002 | 04:13 PM
NZConvertible's Avatar
I'm a boost creep...
Re: TID Question
That crankcase ventilation line can be open vented without any problems and won’t be the cause of your vac leak. That’s probably caused by your new TID not being clamped down properly and leaking unmetered air into the turbo. Double check your installation, make sure it seals properly.
Old May 20, 2002 | 09:20 PM
viperkiller7's Avatar
1.3 liters of whoop ass
So teh two lines that went to the tid you don't need at all... wasn't one for the boost solenoid
Old May 21, 2002 | 01:33 AM
Originally posted by viperkiller7
...wasn't one for the boost solenoid
That's for 89-91 cars only.
Old May 21, 2002 | 01:55 AM
hypntyz7's Avatar
Your vacuum leak might be your stock blowoff valve, depending on what you did with it...you cant just leave it open air vented without a check valve in fron tof it, as it leaks at idle. The other small hose can be left as-is.
Old May 28, 2002 | 11:37 AM
TurboMike's Avatar
i have an aftermarket blow of valve, still haven't tracked down that vacuum leak and my car is running like ****..... (it pulls 10 mm/hg on the boost gauge when idling, somtimes less)
Old May 28, 2002 | 12:00 PM
vosko's Avatar
when all else fails use carb cleaner to find the vacuum leaks
Old May 29, 2002 | 08:42 AM
TurboMike's Avatar
how do you use carb cleaner to check for vacuum leaks??
Old May 29, 2002 | 08:52 AM
The Ace's Avatar
Greek Power
With the engine running, start spraying CC area-by-area. When you hear the engine drop its revs, it means that CC was "sucked" into the engine by a small hole somewhere. Thats your leak. Go into more detail (micro-spray around every single line/hose) and you'll find it...
Old Jun 2, 2002 | 02:52 PM
böst's Avatar
Actually, carb cleaner is combustable. If your revs drop when you hit the leak, then you aren't spraying carb cleaner. The engine rpm's should rise whenever you spray the carb cleaner on the leak, beacause it will suck in the cleaner and burn it up.
Old Jun 3, 2002 | 01:46 AM
The Ace's Avatar
Greek Power
Well, yeah I thought so too, until I actually did this, using GoldenEagle CC, and when the CC was sucked into the engine, the engine would almost stall if I didnt give it any gas...
I know its supposed to be flammable, but if it replaces the oxygen, then...
Old Jun 14, 2002 | 07:37 PM
Ryde _Or_Die's Avatar
Anyone have pics of what to do with the stock BOV? I want to do the TID mod but haven't a clue what to do with it. This is the site I am going on:
http://2ndgenrx7.freeservers.com/techmaster.html
If anyone has a better one let me know.
Old Jun 14, 2002 | 08:20 PM
BlackRx7's Avatar
Daily Domestic Killer
so your not suppose to block off the crank case ventaliation, I did, should I put a check valve there or will it not matter if it is open?
Old Jun 14, 2002 | 09:00 PM
Bambam7's Avatar
I came, I saw, I boosted.
You can use regular propane too.. (unlit of course!!!!!!!!)
Just turn it on and wave it around the inatke area and hoses... if the revs RISE, then propane is getting sucked in- leak.
Old Jun 14, 2002 | 10:58 PM
Amur_'s Avatar
Refined Valley Dude
You're less likely to blow yourself to Kingdom Come with CC.
Old Jun 14, 2002 | 11:08 PM
Old Jun 14, 2002 | 11:42 PM
rx7_turbo2's Avatar
Professor D.P
That silver check valve is just fine open vented, there is no need to cap it or plumb it back into the intake, it might on occassions spew some gross waz however, no big deal.
Old Jun 15, 2002 | 01:09 AM
BlackRx7's Avatar
sweet thanks man
Old Jun 16, 2002 | 06:41 AM
No pics, but enough info...
DIY open-vented BOV
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
