noob in need of help
Old Jan 8, 2009 | 11:45 AM
MIDWESTSTYLE's Avatar
hey guys i was wondering what the line that comes from the banjo bolt on the twin scroll actuator connects to.
almost done fixing my fpd fire damage
Old Jan 8, 2009 | 01:49 PM
Aaron Cake's Avatar
Engine, Not Motor
You'll find full vacuum diagrams in the FSM, which you will find in the 2nd gen FAQ.
Old Jan 9, 2009 | 02:33 PM
new problem...does anybody know the size of the coolant banjo bolt on the turbo???
Old Jan 10, 2009 | 10:27 AM
Aaron Cake's Avatar
Engine, Not Motor
I want to say M14, but that might be wrong. It probably is. Best bet is to just take one to the fastener store and ask them to match.
Old Jan 10, 2009 | 11:36 AM
i believe my friend misplaced the bag that had the original in it. so i am trying to get the size so i can buy a new one..and nobody around here carry's banjo bolts big enough..it sucks!!! its like the last part i need to get it driving again!!
Old Jan 10, 2009 | 08:58 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You can always make your own if you can find the right size bolt. Drill a hole up the center, and one horizontally. Just be careful if clamping the threads, since that could cause a leak later.
Or apparently you can find them on ebay, hah. Found this M14 x 1.5mm:
http://cgi.ebay.com/ebaymotors/M14-x...QQcmdZViewItem
That's just an example though. I'm not sure what the pitch is or if M14 is even right.
Old Jan 11, 2009 | 10:18 AM
Aaron Cake's Avatar
Engine, Not Motor
You must have a local hydraulic shop that can handle this. Failing that, a local fastener store. Just check the Yellow pages.
I just searched for the banjo size, and it's actually M16 x 1.5, not M14.
Old Jan 11, 2009 | 11:46 AM
thanks!!!!!! i am going to call around tomorrow to see if i can get it
whinin
Mar 30, 2019 07:53 PM
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
RXeckless
Sep 12, 2015 04:52 AM
Archangel Studios
26
Dec 13, 2003 04:20 AM
