car shakes when i brake hard
Old Jan 7, 2009 | 05:09 PM
chuchrx7's Avatar
NY car shakes when i brake hard
could it be the tires
Old Jan 7, 2009 | 09:15 PM
Shadow102's Avatar
Eneman to the Rescue
if only on braking your rotors are warped
Old Jan 7, 2009 | 11:48 PM
Michaelangelofb's Avatar
yeah if it is safe to have the rotors turned start there.. If you cant turn them get new ones cant hurt to check your alignmnet too depending on how long it has been shaking,
Old Jan 7, 2009 | 11:52 PM
diabolical1's Avatar
welcome to the board.
your rotors are done!
Old Jan 8, 2009 | 01:04 PM
celbii's Avatar
jackie chan > chuck norri
When i replaced my rotors at napa it was pretty cheap under 100 for all 4 i believe.
Old Jan 8, 2009 | 03:58 PM
Memphis's Avatar
Ringer
I wouldn´t use 25$ rotors on a 259rwhp car. I had mine turned and have no more shaking since then, but check if there´s enough meat first.
Old Jan 8, 2009 | 04:15 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You can only have them turned so many times. There's a minimum thickness of something like 20mm.
Name-brand non-drilled rotors don't cost that much, so $25 is perfectly normal. It's the overpriced drilled / slotted ones that tend to crack anyway, so price does not always equal reliability.
Old Jan 8, 2009 | 04:30 PM
Memphis's Avatar
Ringer
Fully agree on the non-drilled ones being better. Didn´t know they are that cheap in the states.
Old Jan 8, 2009 | 04:39 PM
userjh5174's Avatar
Re-surface your rotors or get new ones.
Old Jan 8, 2009 | 04:50 PM
cyipher's Avatar
agreed
Old Jan 8, 2009 | 09:44 PM
Chupacabra's Avatar
65 Beaumont
Bad news
brake shoes??
Old Jan 9, 2009 | 01:52 AM
no drums ...
Old Jan 12, 2009 | 02:53 PM
84gs_rx's Avatar
i bought two new premium rotors from napa for 100 bucks they seem to be doing the trick
astrum
24
Nov 15, 2017 08:44 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
GrossPolluter
Aug 16, 2015 09:50 AM
Marty RE
Aug 13, 2015 11:19 AM
