about oil cooler
Old Jan 6, 2009 | 12:20 AM
banski's Avatar
IL about oil cooler
i have the FD 1993. i got t78 greddy turbo kit with 3000miles on new engine.
here is the question. my car is not R1 nor R2. i think it's base model. should i get the oil cooler? or i can drive my car without oil cooler?
Old Jan 6, 2009 | 04:48 PM
dgeesaman's Avatar
How much power are you making with this setup? Will you be using the car on the street, for drag racing, road racing? What upgrades do you have to your cooling system?
Ultimately the way to know is to watch your oil temps. Depending on your usage, power level, etc you may or may not need the extra oil cooling.
Old Jan 8, 2009 | 03:13 AM
krizu's Avatar
All FD3S have at least one oil cooler, right? But Type-R and Type-RZ has two...
Old Jan 8, 2009 | 03:19 AM
DrKillJoY's Avatar
Administrator
In the US where the OP is there were no Type R or Type RZ models.
We did however had R1 and R2 models which had two oil coolers. All other US models (base, touring, PEP, PEG) had one oil cooler as factory equipment.
Old Jan 11, 2009 | 04:22 PM
banski's Avatar
my car makes about 350whp. unfortunatly when they rebuilt it they used stock fuel pump and stock fuel injectors.(according to previous owner).
need to change them and dino again. i drove 5times or 6times total after i bought the car because chicago weather sucks!! FD is in my garage.
when spring comes up gotta work on it. should i put extra oil cooler?
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
