Need help deciding what to do with my RX7
Old Jan 4, 2009 | 11:29 PM
mura8898's Avatar
Hey everyone...
I picked up a '88 GXL rx7 n/a for 300 bucks a week ago.
Now the trouble that I am having is, what to do. The engine is not running at the moment, and the body needs work. I'm currently in the process of yanking out the engine, which will be happening in the weekend to come.
I need help as to what to choose
Rebuild my 13b n/a engine
or go to a Turbo II setup
or it is there any other type of engine mod I should do? (oh please no V8 suggestions hehe, is my first time playing with rotary and I wanna keep it rotary)
I'm trying to shoot from 350-400 hp
any type of suggestions would be great, this will also be a daily driver.
Old Jan 5, 2009 | 10:11 PM
farberio's Avatar
NASA-MW ST4
If you are shooting for 350-400 mods...you are looking at a turbo motor, with a bigger turbo and all the supporting mods. Probably a full stand-alone as well.
Old Jan 5, 2009 | 11:50 PM
Cwhite89's Avatar
Go with a turbo II swap cause ull never get 350-400hp out of an N/A! Yeah im with you on the v8 swap i love the rotary engine and u can easily get just as much Hp out of a rotary as you would a V8!
Old Jan 6, 2009 | 11:32 AM
mura8898's Avatar
I just picked up a turbo II tranny and turbo II LSD with drive shaft for 300 dollars. I'm about to go and grab a Turbo II motor pretty soon and take a look at it. Now, would I need to do any porting?
What is the next step after getting the Engine and ripping it apart?
Old Jan 6, 2009 | 12:49 PM
RxFuel's Avatar
Ten cents gets ya nutz!
Search around there are lots of threads on this, on rotary resurrections home site they have a good list of all you will need and such
http://www.rotaryresurrection.com/2n...to_turbo2.html
Old Jan 6, 2009 | 04:18 PM
tasty danish's Avatar
Doesn't suck
As others have said, search for real answers.
Just to answer your question, you don't NEED to port to hit 350-400. Most recommend it, but turbos can do anything.
You WILL need a stand alone ECU (Haltech or similar) and a happy fuel system.
350-400hp won't require too many retarded tricks as far as the engine rebuild goes. should be pretty standard. Look up rotary aviation and get their rebuild video, good stuff.
Then go to nopistons.com make an account, and look in the "rotary building and porting" for some AWESOME tricks and tips.
Old Jan 6, 2009 | 04:48 PM
mazdaracer78's Avatar
wankel head
VA engine generation consideration
if you are shooting for 350-400 hp you should really consider doing an s5 (89-91) on up block or at least do an engine stud kit. the s4 tII rear plate has a frail dowel seat which will not hold up repeatedly to that kind of hp. at bare minimum, consider doing a s5 rear side plate. they are interchangeable. the s5 dowel seat should be strong enough to handle the extra hp. in other words an s4 engine can not hold up to the repeated stress (twisting, torque, ie) of that much more hp.
Old Jan 7, 2009 | 01:15 PM
mura8898's Avatar
Hey great, thanks for the links. I've already begun to take a look at these links. Also, thanks for the info on the durability mazdaracer78.
Old Jan 7, 2009 | 02:24 PM
prdclson7's Avatar
def. turbo 2 swap
Old Jan 8, 2009 | 09:21 AM
RxFuel's Avatar
if you do decide to go forward with the build, make a thread and post some pics others will be able to help you in the process
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
Th0m4s
Feb 26, 2019 02:04 AM
JBatista1994
Aug 14, 2015 11:23 AM
