Did the fuel filter relocation.
Old May 19, 2002 | 10:41 PM
7-sins's Avatar
thats not paint....
Thumbs up Did the fuel filter relocation.
Me and Ryan (Dont_be_a_rikki) spent the whole saturday working on our 7s. Here is the list of everything we did to my car:
Fuel Filter relocated
Reset the idle screws
Adjusted my E brake because you had to pull the handle up almost 20 clicks
Found my freon leak
Noticed that my front swaybar braces were bent so we bent them back
Spayed WD40 on my drivers door handle because it was sticky.
Adjusted my midpipe so it didn't rattle against my car
The fuel filter wasn't that hard since the car was up on a lift... Just a pain. The new fuel filter went in a snap. On the drive home I noticed a little more fuel smell than normal but there is no leaks. I will see if that dies down in a week or so. The car has run a lot smoother though and no more stalling.
Also test fitted a wing on my car... what do you guys think:
Old May 19, 2002 | 11:15 PM
007007's Avatar
what sort of filter did you use?
Old May 19, 2002 | 11:38 PM
7-sins's Avatar
thats not paint....
K&N billet aluminum filter with 5/16" barbs.
It is washable and reusable, holds up to 6000psi, and filters down to 10 microns.
Cost me 50$
Old May 20, 2002 | 12:35 AM
GsrSol's Avatar
Z06 powered FD
Sounds like you 2 had fun and got alot accomplished!
Personally I think the wing is a little too much since the rest of the exterior is stock.
Old May 20, 2002 | 12:37 AM
Lost Time's Avatar
Chimera Driver
If anyone is looking to relocate their fuel filter, I have the filter and necessary fittings for sale. I bought them, but decided not to use them. Drop me a pm if you are interested.
Old May 20, 2002 | 12:42 AM
ziftar's Avatar
Rotor Head
I'd be real interested in seeing a pic of your relocated K & N fuel filter. The wing looks good!
Old May 20, 2002 | 12:51 AM
7-sins's Avatar
thats not paint....
That was my first thought as well. I'm looking to buy the C-West kit like the one in your avitar by the end of the summer. I might stick it on before that, who knows.
Sure thing man let me get my hands on a digital camera. If not during the week then by the 25th.
Old May 20, 2002 | 01:11 AM
JConn2299's Avatar
reliable performance
The wing looks fine. The car looks good. It's a nice clean look. Don't mess it up with a lot of add on junk.
Old May 20, 2002 | 01:47 AM
luneytune's Avatar
So where was your Freon leak? Mine is gone, has been since before I had it.
Old May 20, 2002 | 02:33 AM
7-sins's Avatar
thats not paint....
The leak was on a line going to the compressor. When your standing at the nose of the car there is a line comming out from the right and from behind the compressor. The one to the right of the compressor was leaking. You couldn't tell one bit until we got the freon detector out. I think the O ring in that fitting is bad so I will replace then try. Next time your under you car look around for a freon stain, looks like a yellowish residue. I saw this on the back of my plastic under gaurd so I had a general direction to look in.
Old May 20, 2002 | 10:28 AM
luneytune's Avatar
I'll check it out. Thanks.
Old Jul 24, 2002 | 01:23 AM
Nameless's Avatar
You just replaced the old fuel filter with a line? 5/16 I am guessing? Did you have to clamp that replacement line as well?
I think you got the mini K&N filter, there is a larger one for automotive use right? Are both safe to use on our cars?
Old Jul 24, 2002 | 05:55 AM
jspecracer7's Avatar
1JZ powered
return of the old thread...
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
The1Sun
Mar 18, 2018 11:08 PM
HDA
Nov 3, 2015 03:49 PM
