Megasquirt Question for moderator
Old Jan 4, 2009 | 11:10 AM
chango de naranjito's Avatar
I plan to do a instalation for a friend,and whant to use a msd 6a ignition box here is my question,can I use an igniter to sen the signal to the white wire of the msd? I plan to use a toyota tacoma igniter becose I know it uses a 5v signal to fire 3 coils(I work for toyota) and send the coil- to fire the coils it that posible?
Old Jan 4, 2009 | 06:47 PM
muythaibxr's Avatar
MegaSquirt Mod
I don't know, we used a Crane unit to fire leading on a friend's rx7 by letting the crane take a signal from the stock ignitor.
I've never used the MSD unit.
Ken
Old Jan 4, 2009 | 10:56 PM
Ken
the other thing that came to my mind is using a Bosch BIP373 Coil Driver to send the signal to the msd because the msd uses the negative terminal of the coil to fire. and triger the driver from pad1 of the v3.57 what you think?
Old Jan 5, 2009 | 03:22 PM
muythaibxr's Avatar
MegaSquirt Mod
Again, I don't know anything about the MSD unit. I'd need to see the manual for that.
Ken
Old Jan 5, 2009 | 11:33 PM
elturbonitroso's Avatar
you can drive the msd directly from the - side of the led but i dont know if you can use the spark output invert with the rotaty engines.
Old Jan 6, 2009 | 05:09 AM
pmrobert's Avatar
GIS is your friend - http://www.megamanual.com/ms2/msd6a.htm
Old Jan 6, 2009 | 06:43 PM
Originally Posted by pmrobert
that should work.
Old Jan 6, 2009 | 08:39 PM
PR
Originally Posted by elturbonitroso
that should work.
ok I got it!!!I dont know why I dont think this before, is more easier to conect the stock coils from a turbo II with the shock igniters and conect the msd from the negative terminal of the coils to the white wire of the msd box to triger the msd unit
Old Jan 6, 2009 | 08:54 PM
thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 7, 2009 | 06:00 PM
or if you want a clean look you can do the 2n2222 circuit if its prove that works and you dont have to use the t2 igniters.
Old Jan 7, 2009 | 07:25 PM
but I think the 2n2222 transistor trigers with a 5v signal and the signal of the leds is a ground swithing signal, I am right?
Old Jan 7, 2009 | 11:47 PM
i think that you're right but option 1 i think that you can use the top of r26,27 and 29 for that or option 2 use a 5volt pull to trigger the 2n2222.
Old Jan 8, 2009 | 06:44 AM
pmrobert's Avatar
Re the 2222 - it makes absolutely no difference logically if vcc(+) is constantly provided and the ground(-) is pulsed as opposed to constantly grounding the appropriate pin and pulsing the vcc(+). GIS these terms: NPN, PNP, source vs sink vs drain, pullup, pulldown. With a little creativity, careful deliberation and self education you'll be able to fully understand the concept of using a transistor as a high speed switch and be very comfortable with what you come up with. Yes, you can switch 12v with a logic level (5V) pulse.
-Mike
Old Jan 8, 2009 | 04:52 PM
-Mike
Old Jan 8, 2009 | 08:19 PM
pmrobert's Avatar
Just trying to help. My apologies.
Old Jan 9, 2009 | 06:35 AM
no no no sorry I dont mean that, is just dont understand all the terms I am new to all this electronic stuff you know and whant to learn everything I can from you
Old Jan 10, 2009 | 07:07 AM
pmrobert's Avatar
Apologies for the inadvertent apology, I misinterpreted your message! You have PM....
-Mike
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
