Rotary Drag Racing The place to post your racing stories and info
Dyno Sheets
Old Jan 3, 2009 | 07:20 PM
4sfeedit's Avatar
Dyno Sheets
Here is some more runs and some with torque.
Old Jan 3, 2009 | 07:34 PM
crispeed's Avatar
'Tuna'
Where did you pickup the rpm from?
Old Jan 3, 2009 | 07:41 PM
4sfeedit's Avatar
Those ones we threw it on the wires.
Old Jan 3, 2009 | 08:16 PM
crispeed's Avatar
'Tuna'
Be carefull!
Old Jan 3, 2009 | 08:34 PM
4sfeedit's Avatar
Never had a problem. With factory coils/wires.
Old Jan 3, 2009 | 08:41 PM
crispeed's Avatar
'Tuna'
As long as you keep the pickup away from another lead everything will be ok but I know you knew that allready!
Old Jan 3, 2009 | 08:50 PM
4sfeedit's Avatar
I use to have problems when I used aftermarket coils and boosters. Always had to be careful how I placed the wires and dealing with misfires, rfi, etc.
Factory coils and factory wires is what lit up 45psi.
Old Jan 3, 2009 | 09:00 PM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Hmmmm.......
Old Jan 3, 2009 | 09:12 PM
4sfeedit's Avatar
Originally Posted by internal comsucktion engi
Hmmmm.......
Question?
Old Jan 3, 2009 | 10:03 PM
13B-RX3's Avatar
7s before paint!!!
Is this a three rotor?
Old Jan 3, 2009 | 10:22 PM
4sfeedit's Avatar
S5 13bt
Old Jan 3, 2009 | 10:27 PM
13B-RX3's Avatar
7s before paint!!!
S5 13bt
I guess it i would have read the dyno sheet
Very impressive! Care to share the specs? What fuel and turbo and most importantly, what's it in
Old Jan 3, 2009 | 10:37 PM
4sfeedit's Avatar
The specs
S5 half bridge
pinned and clearanced
high comp turbo s5 rotors
Fuel is q16 75%+ 25%vpimport
stock fuel rails 1680ccx4
Surge tank+ 2 intank 255+ 2 inline 255ho
Stock intake s5
Stock TB s5
Turbo S480 T4 110 small shaft+rear wheel
Microtech lt10 X-4 + factory t2 coils
E-boost 60 psi
Boost 44psi peak steady@42
Engine 60 000km
Built and Tuned @Forcefed Racing
Marko Stilinovic
Old Jan 3, 2009 | 11:09 PM
tearbo2's Avatar
The specs
S5 half bridge
Stock intake s5
Stock TB s5
E-boost 60 psi
Engine 60 000km
Marko Stilinovic
hey marko, what clutch do u have?? cuz iv'e had nothing but problems.... ran my setup @ 42 psi and couldnt get traction or keep the clutch engaged if i wanted to, never got a dyno # at 40+ psi but im sure it was over 800 rwhp
good luck !!! I ran 9.85 w/ a "on da rivets" act 6 puck @ 30 psi !!!
Old Jan 3, 2009 | 11:39 PM
ErnieT's Avatar
Living life 9 seconds at a time
Congrats again, Marko. Thats some sick power.
Old Jan 3, 2009 | 11:44 PM
ultimatejay's Avatar
Uh OH we have some dyno competition going on now.
Great numbers, when do you plan on running the car at the track? Track numbers is what really matters.
Old Jan 3, 2009 | 11:45 PM
4sfeedit's Avatar
I use a ACT with some mods done to the pressure plate. Also we have a progressive boost system that is easy on the driveline and gives everything a chance. When I owned the car, it went 10.0 @148 with 690rwhp (consistant), with all factory drivetrain. We will see what happens with the new power. We will be making up time after 60ft.
Old Jan 3, 2009 | 11:46 PM
OneRotor's Avatar
RAWR
you have some competition ErnieT.
Congrats on the numbers, that's damn impressive. Are you using S5 plates or S6 plates (or is it only the S4 plates that i've heard of people cracking really badly?)
Old Jan 3, 2009 | 11:50 PM
4sfeedit's Avatar
As soon as it clears up. This is our fun this time of year. Remember I live in Vancouver, Canada.
http://ca.youtube.com/watch?v=ongx3FeM06I
Old Jan 3, 2009 | 11:52 PM
4sfeedit's Avatar
The engine is 100% s513bt
Old Jan 4, 2009 | 12:02 AM
tearbo2's Avatar
sounds good, but in drag racing it's all in 60ft_330ft you can have all the power u want, but it is what it is ....... it's sounds to me like a "honda" way of thought run it easy on the bottom and try and catch em on top, if you weigh in at 2400 and lower i can see it , but if ur like me (2792) good luck ...... i got a twin disk tilton that i "fixed" that i will try again, act didnt come close .............
Old Jan 4, 2009 | 12:04 AM
tearbo2's Avatar
damm that looks like a LOT of fun !!!!!!
Old Jan 4, 2009 | 12:14 AM
4sfeedit's Avatar
I know that drag racing is all in 60ft. That is why you build a car to master 60ft. In this case you are dealing with a car with factory equipment in the ***. And my point is to go as fast as you can with factory driveline. This unfortunatley means taking it easy off the start. A factory gearbox is very fragile as we all know. You have to give it a chance! Multi disc clutches eat factory gearboxes. And hard launches eat axles+stubs. The car has done numerous passes and is still using the 2 year old ACT combo.
Marko
Old Jan 4, 2009 | 12:39 AM
tearbo2's Avatar
Marko
trust me, I know all bout that I too am runnin factory diff, but i am runnin the dss "bullet proof" axle setup, which is holdin 1.4 60ft all day long . can't say the same for the tranny tho I got (2) more trannys left before i go w/ the g force tranny, my goal is to beat the factory gear box record held by ari 9.27 , but it's alot harder than making "dyno numbers"
best of luck w/ ur ACT COMBO
Old Jan 4, 2009 | 02:22 AM
AnthonyNYC's Avatar
Stay tuned...
Congrats on the numbers and good luck this season. Just curious what apex seals you are using....
