89 RX7 Wont Start After rebuild Engine. (With Vídeo link)
Old Dec 28, 2008 | 08:00 PM
Nelio's Avatar
PR 89 RX7 Wont Start After rebuild Engine. (With Vídeo link)
Hello to all of you!
I'm From Portugal and I have a strange problem with an 89' RX7.
Well, the car was stopped for 4 years until I can repair It, now a new rebuilt engine was mounted and all of the connectors checked. The "only" problem is the car Wont Start. I have tried and checked for all connectors sprayed and nothing... He wants to start but something is wrong.
I have made a vídeo with the car trying to start and in that video you can see a test I did to the plugs. I don't know what to do more and the local dealer is crap. anyone had this problem before?
Here is the vídeo:
Old Dec 28, 2008 | 11:54 PM
farberio's Avatar
NASA-MW ST4
Check for fuel. If there is fuel do the de flood procedures.
If you used new apex seals and old housings it will be a rough start until its broken in.
You may need to play around with the throttle to get it to start.
Old Dec 29, 2008 | 12:59 AM
lele73's Avatar
15U24
make sure your fuel lines arnt crossed. i did that once. switched them and she stared right up. BTW DON'T Burn out your starter!!!
Old Dec 29, 2008 | 02:54 AM
Nelio's Avatar
Question
Hello, Its not Flooded, I even take the spark plugs out and cleaned Them. Fuel lines crossed is more likely to happen... Can anyone put a pic os a scheme for that? Without the sparks in the place and starting the engine, gasoline comes out the holes.
The starter engine I think it has revealed the strongest part of the car... I am trying this for 4 or 5 days.
Old Dec 29, 2008 | 12:20 PM
Nelio's Avatar
Talking
Well Guys... after folowing the steps here -> http://www.rotaryresurrection.com/2n...p_breakin.html FINALLY the engine started... It was flooded.
Video: --> http://www.youtube.com/watch?v=v96JLn2uIfI
BUT, major oil leak appeared... behind and below the intercooler, and went down passed the gearbox to the floor.
Step one completed, now I have to find wats the problem. Any ideas?
OIL LEAK Pic
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
