No oil pressure ?
Old May 19, 2002 | 12:25 AM
von's Avatar
von
No oil pressure ?
My turbo lost all its oil compression? Is this a failing pump? Is thier a connector for this or what? thnx
Old May 19, 2002 | 12:31 AM
Silkworm's Avatar
Has been.. hangin' around
The oil pump is chain driven inside the front cover. Check the connector on the oil pressure sender, make sure that line didn't break or come off. Chances are, you might have dislodged it. Because if you truly don't have oil pressure, you're forked.. 'Cause it's engine pull time.
PaulC
Old May 19, 2002 | 12:42 AM
von's Avatar
von
Wheres the oil pressure sender...THnx silk.
Old May 19, 2002 | 01:01 AM
Silkworm's Avatar
Ok, Under the oil filter, you've got a big ole' heater hose. Behind that, you'll see this mushroom shaped metal thing sticking out the side of the block, with a slide on connector on the end of it. That's the oil pressure sender.
G'luck.
PaulC
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
