got a question NEED HELP!!!????
Old Dec 23, 2008 | 09:13 PM
ec4evany's Avatar
FL got a question NEED HELP!!!????
hey im tring to find out if anybody could help me out im tring to find out if a regular non turbo wiring harness would work on a turbo motor would it work has any one tried it out? thanks id really apreciate it if someone would get back to me thanks
Old Dec 24, 2008 | 09:01 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Of course. It's the best way to swap in a turbo motor since it requires the least rewiring.
You didn't specify a year of car, so for S4s you need to cut the wire at ecu pin 1R or wire it up to a knock control box. The knock box is pretty useless, so I ignored it. Next, extend the tps and BAC wires so they will reach the new locations. Last, if you're using an S4 turbocharger, run the wire from pin 2K (split air solenoid plug) to the twin-scroll solenoid. That's it.
S5s are even easier. The BAC wires are already long enough, so just extend the ones for the tps. Connect the 6PI solenoid plug to the turbo duty solenoid, and the VDI plug to the knock sensor (just 1 wire) and you're done.
ECU pin differences:
****************** S4 ***********************
1R: NA - P/S Switch, Turbo - Knock Sensor
2K: NA - Split Air Solenoid, Turbo - Twin-scroll Solenoid
3D: NA - Inhibitor Switch (AT only), Turbo - Fuel Resistor/Relay
****************** S5 ***********************
2M: NA - VDI Solenoid, Turbo - Knock Sensor
3R: NA - 6PI Solenoid, Turbo - Turbo duty Solenoid
Old Dec 27, 2008 | 10:25 PM
MMoore4545's Avatar
Wow, seems like that is too easy
thanks for the info, looks like daddy's going turbo for the new/year
Old Dec 28, 2008 | 03:21 AM
`fknfc-7's Avatar
thanks
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
