Mixture Adjustment???
Old May 18, 2002 | 03:17 PM
BlackRx7's Avatar
Daily Domestic Killer
okay I just recently install a Air/Fuel Gauge and at idle , its all the way rich, I belive that it's suppose to be stoich right?
anyway any input is greatly appreciated
Old May 18, 2002 | 03:31 PM
Keith's Avatar
No, at idle it should read lean. The actual mix is adjusted by varying the mixture adjust screw for max idle with the test connector installed. This only affects idle! When it is adjusted, you will probably end up with about 13:1 or so, but port air injected by the air pump via the Air Control Valve will will force a lean reading. Hope this helps.
Irv, Keith's dad
Old May 20, 2002 | 12:04 AM
BlackRx7's Avatar
Okay, I just took my avc off, and the air pump and cat have been removed
Old May 20, 2002 | 12:45 PM
BlackRx7's Avatar
its the one that was in there when I bought the car, just was wondering if there is a way to actually adjust the mixture via a screw or something
Old May 20, 2002 | 12:55 PM
Fingers's Avatar
i'm afraid not. You can control the idle mixture, but thats bout it. check your error codes of your cpu to see if there are any problems with your sensors. That should do it.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
LongDuck
Oct 7, 2015 08:12 PM
93FD510
Oct 1, 2015 02:00 PM
Turblown
Sep 30, 2015 05:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
