starting issues
Old Dec 15, 2008 | 04:52 PM
truckinman9181's Avatar
AZ starting issues
so i let my se sit for 3 days and this morning when i tried to start it, it fired then died. i tried pumping the gas and it tried to fire but wouldnt so i kept cranking on it and finally she fired over after about 45 seconds but kind of sputtered for a few minutes. i revved it up and it shot a flame out of the exhaust pipe. after that she ran ok. anybody got any suggestions?
Old Dec 15, 2008 | 06:39 PM
Jarsky's Avatar
much moisture in the air? could have just had some moisture build up for some reason
Old Dec 15, 2008 | 06:41 PM
AZ
a little moisture here but not much. if i let it sit over night it will sputter when i start it but never this bad
Old Dec 15, 2008 | 06:56 PM
BeenJaminJames's Avatar
Lurking on thread near U
Sounds like it might be flooding to me. The thing about a rotary is when its flooded it can sit for a week and still be flooded. And if you kill the engine before it warms up fully, it will flood out. So always let it idle untill it warms up, and the next time it has a hard time starting like that, try this:
Pull all the plugs, and crank the car for about 10 seconds, then dry off the plugs and put them back in. If it was flooded, that will air it out.
Old Dec 15, 2008 | 07:43 PM
I love pop-up lights's Avatar
The Assistant
Sounds like flooding like the others said. If all you did was let it sit for awhile it's most likely a leaky injector. My old 7 did it all the time. More than 3 days....flooded. Check your plugs for fouling since it flooded, if so wipe em off if their still passable. Another trick you can use is to pull the EGI fuse and crank for 15-30 seconds, put the fuse back in and that usually does the trick.
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
FB_Frank85
Aug 31, 2015 03:31 AM
befarrer
Aug 14, 2015 04:18 PM
