megan or 5zigen
Old Dec 13, 2008 | 02:28 PM
hbomb86's Avatar
megan or 5zigen
which exhaust would be better for a turbo II motor boosting about 13psi
Old Dec 14, 2008 | 10:51 AM
Aaron Cake's Avatar
Engine, Not Motor
Both of those exhausts are cheap and I personally think they sound awful. You may like the sound if you like the car sounding like a chainsaw on crack or the typical Honda with a fart can.
However, at 13 PSI you're out of the efficiency range of the stock turbo. You're starting to push more heat which is going to significantly decrease turbo life and make it a lot easier to pop the engine due to high IATs. Also keep in mind that you are out of the capability of the stock fuel system so you will need as set of upgraded secondary injectors, some way to control them, and perhaps a pump upgrade. An FCD is require to stop the stock ECU from hitting fuel cut.
Old Dec 14, 2008 | 11:47 AM
diabolical1's Avatar
agreed. get more robust parts for your exhaust setup. also, don't try to raise boost until you can do it safely.
Old Dec 15, 2008 | 08:03 PM
hbomb86's Avatar
already have upgraded turbo and fuel pump and injectors . . . . . thanks for looking out also have the boost controller and turbo timer. . . . . just posting so i can use all the functions of this site.
Old Dec 27, 2008 | 08:33 PM
MMoore4545's Avatar
Actually have a pair of Magna'flow cat-backs on it that sound great..
bought it that way
didn't think it would sound as good as it does.
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
