More brake pad questions: angled plate
Old May 17, 2002 | 04:20 PM
WKeene's Avatar
Question More brake pad questions: angled plate
Hey guys.
I pulled off my 4 piston brake pads and noticed something a little peculiar.
The 2 metal plates that come into contact with the pistons don't appear to make complete contact with the angled. plate. I'm basing this on the witness marks on the angled plate.
Its appears that part of the piston hangs off the edge of the angled plate.
Is this correct? I'm concerned that someone didn't assembly this correctly or used wrong parts.
Take a look at the attached pics and you'll see the witness marks where the pistons contact. I guess it could be designe this way. Not sure why.
Thanks for your help.
Old May 17, 2002 | 04:26 PM
WKeene's Avatar
2nd pic: Brake pad assembly
Old May 17, 2002 | 04:31 PM
WKeene's Avatar
3rd pic: Separated assembly - 3 pcs
Angled plate
Solid plate
Pad Back
Old May 17, 2002 | 05:27 PM
Matlock's Avatar
If it makes you feel better mine were identical. I think thats just the way they are. :=)
Old May 17, 2002 | 05:50 PM
maxpesce's Avatar
Ex fd *****
Looks correct to me - the fd shims go together the same way - just make sure the arrow points the same direction as the brake rotation (when going forword! :-) ) and you will be fine.
Old May 17, 2002 | 11:37 PM
WKeene's Avatar
Yeah....I looked at the exploded diagram in the manual...looks right, weird though.
Thanks for the confirmation.
djritz
Aug 25, 2015 02:46 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
