apexi ecv
Old Dec 9, 2008 | 06:54 AM
wackaloo13's Avatar
apexi ecv
If i were to install an apexi ecv (exhaust control valve) where should i put it for maximum silencing. The dp is 3" and it jumps up to 4" when the wastegate recirculates. Should i place the valve:
1. Right at the outlet of the downpipe? It would be a (80mm valve.
2. Before the center muffler but after the wastegate recirculates at which point it would be a 95mm valve.
3. After the middle muffler. a 95mm valve would be fitted
Has anyone had any experience with these valves?
Old Dec 13, 2008 | 01:25 AM
wackaloo13's Avatar
i got the fabrication bug so i decided to make my own. pictures to come
Old Dec 13, 2008 | 05:45 AM
wackaloo13's Avatar
the thread is in the fabrication forum
ls1swap
Jun 3, 2024 03:25 PM
