Trying to get my FC running
Old Dec 8, 2008 | 08:32 PM
rotarydreams89's Avatar
Previous RX Driver
Question Trying to get my FC running
I purchased my FC in July of 2007. When i drove it, it would overheat and sometimes not start. I later found out that the catalytic converter was clogged. After repairing it at a muffler shop it ran until January of 2008. In that time period i went throught two alternators too. The engine cranks but doesn't start. It has 129,000 miles on it. Before it stopped running it began overheating again. The temp read past the H on the meter. A mechanic told me that the engine has low compression. Is it time for a rebuild or is there anything else i can do just to keep it running?
Old Dec 8, 2008 | 08:53 PM
IanS's Avatar
Ricer
You should check the compression yourself just to make sure. There are threads that explain how to do this. Overheating a rotary is normally a very bad thing so it is likely that it needs a rebuild but check compression first to make sure.
Old Dec 9, 2008 | 05:20 PM
JoeyMazda's Avatar
"81 RX-7
I work with my own car am a rotary mechanic and I've seen this problem many times.Most likely you might need to overhaul the engine and need new housings because that's what might be causing your overheating problems. Buy a rebuilding kit and new housings.Rebuilding the engine alone won't help.
Old Dec 10, 2008 | 01:12 AM
Previous RX Driver
Smile Thanks for the advice
You have been very helpful. I will see what i can do. I did have plans on swapping a T2 motor in anyway. I wanted to swap the auto trans for a 5 speed too.
Old Dec 11, 2008 | 01:34 PM
Previous RX Driver
Question T2 Build
Is there a way to convert my NA 13B block into a 13BTblock? What will i need to achieve this build? Roughly how much will it cost?
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
