Sponsored by: CARiD
Real stupid question
Old Dec 8, 2008 | 10:59 AM
zkeller's Avatar
I just put an REW engine back together this weekend, and after bolting the intake, turbos etc back on, I found a side-seal spring laying on the bench! I am thinking that it was a spare but of course I am paranoid now.
I bolted the trans and starter up and checked compression on the engine stand. I get 3 nice even pops on both faces.
I am assuming that I would see virtually no compression on a rotor face if it was missing a side-seal spring, correct? Plus I would have noticed the side-seal slipping completely into the rotor groove when assembling the rotor.
Kind of a curious and mind easing question as I do not want to crack the engine back open unless I have to!
Old Dec 9, 2008 | 12:00 PM
djseven's Avatar
Eh
Do you have any spare transmissions? Remove the bell housing and hook it up to the engine. Jump the starter off of a battery and run a compression test. I would definitely find out for sure before you install the engine.
I dont know what exact symptoms you would see as I have never ran one without a side seal
Old Dec 9, 2008 | 12:05 PM
zkeller's Avatar
That's exactly what I did. I bolted up a spare trans. I did a compression test with the schraeder valve held open and got three nice pops per rotor in the 60 range.
Old Dec 9, 2008 | 04:08 PM
djseven's Avatar
Eh
I would imagine you are good to go but like I said, no real experience in dealing with this.
Old Dec 9, 2008 | 09:05 PM
zkeller's Avatar
Yea, I think so too. I broke a rule that I made with myself. Lay only the parts that go in the engine on the workbench and you will have an empty bench when you are done.
BTW, I assume that you received the rotor housing that I sent to you and thanks for hooking me up with Kevin when I needed a rotor!
Old Dec 10, 2008 | 10:04 AM
djseven's Avatar
Eh
Yes I received it and it was in great shape, I forgot it was you I bought it from. I was extremely pleased with it. No problem sending you to Kevin, he is probably still the most stand up guy in this business though he is barred from this forum.
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
13
Jan 9, 2018 11:19 AM
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
msilvia
15
Sep 11, 2015 12:13 PM
