Turn signal cancel
Old Dec 4, 2008 | 03:37 PM
Zeile's Avatar
Turn signal cancel
just got a fc rx7 89 and my turn signal doesnt self cancel
angle sensor?
canceling cam?
the switch itself?
any ideaa on how i can diagnos the problem
Old Dec 4, 2008 | 04:09 PM
Aaron Cake's Avatar
Engine, Not Motor
Probably the switch.
There's no cancel cam as the switch is electronic (and mounted in the instrument cluster).
Old Dec 4, 2008 | 05:50 PM
AE8616v's Avatar
OGX3
mine doesnt either i thought it was because of the steering wheel the guy i bought my car from installed
Old Dec 7, 2008 | 02:19 PM
Zeile's Avatar
all i know is that it doesnt pass inspection here in MD btw had my mechanic look at it... it is the switch
Old Dec 19, 2008 | 12:52 AM
eage8's Avatar
1308ccs of awesome
take off the steering wheel and and the column shroud and there will be a plastic thing surrounding the column held in by 2 screws. that's the turn signal canclering thing... replace it any you'll be good to go.
http://www.teamfc3s.org/main/factory...cal_System.pdf
Old Dec 20, 2008 | 10:32 AM
Aaron Cake's Avatar
Engine, Not Motor
Yes, the cancel system is totally electronic. If the steering wheel was swapped, the switch may have been damaged.
The1Sun
Sep 18, 2015 07:13 PM
Farkel
Sep 16, 2015 06:16 PM
The1Sun
Sep 15, 2015 04:45 PM
m_haiser
Sep 13, 2015 04:21 PM
