rear end shakes????
Old May 17, 2002 | 12:35 AM
GsrSol's Avatar
Z06 powered FD
rear end shakes????
New problem. When the car is cold and I release the clutch, the rear end will shake. It's not very bad but feels like a minor wheel hop. It's real noticable the first time I release the clutch and goes away after about the first 1/2 mile.
I do still have some air in the brake lines so could that be the problem or does it sound like a clutch, diff problem. Diff fluid is Redline, 2 months old and full. Tranny fluid and clutch are about 8 months old.
Old May 17, 2002 | 10:29 AM
Vintage Red Touring's Avatar
Very strange. My first thought was diff bushings, but if it only does it when cold, that doesn't seem right. How many miles are on your car? If you do a lot of drag race launching, it could be the diff gears/axles wearing out. Another thought is your rear whhel bearings. I'd have Rotary Performance look at it.
Old May 17, 2002 | 10:49 AM
Kahren's Avatar
i am not a girl
i ahve somewhat of the same problem, mine doesnt shake but its clunky in teh back when i just take it out after a couple of miles it goes away.. have yet to cahge teh fluid in teh rear to redline...btw redline takes a bunch of miles fo ru to feel teh diffrence...so be patient it might/shoudl get better
Old May 17, 2002 | 03:56 PM
Darivative's Avatar
You should switch to a turboII rear since it can hold more power than a 3rd gen rear. As far as the shakes it might be the bushings.
Old May 20, 2002 | 01:36 AM
GsrSol's Avatar
Z06 powered FD
Wheel bearings, that's a thought! The wheels not wanting to roll could defiantly cause this stutter.
Anyone have a site showing the wheel bearings? No I don't have a shop manual.
Thanks guys
Old May 20, 2002 | 01:48 AM
here is a shop manual http://www.scuderiaciriani.com/rx7/shop_manual.html
Old May 20, 2002 | 12:39 PM
Wuppy's Avatar
I had this rear end shake problem too and it was really bugging me a lot. It did it when releasing the clutch and more so when starting uphill from standing. Working the clutch when shifting required a lot of concentration to be smooth.
A few weeks ago my clutch blew and I had to put in a new one (total $850). That was the best investment in the car so far. What a difference, its a totally new driving experience. Absolutely no more shaking and ultra smooth shifting, love it!
Your problem sounds like the same.
I put in a street clutch for better drivability and smooth shifting by the way.
Good luck........
Old May 21, 2002 | 02:20 AM
ivanuscg's Avatar
When making a left turn my left wheel tends to shutter. the upper control arm bushing was just changed and it still does it. Any suggestions
Old May 21, 2002 | 08:46 AM
TobiasRX's Avatar
It's probably the rear wheel bushings, if you only hear it when turning.
Old May 21, 2002 | 12:11 PM
Slither's Avatar
If it happens when the clutch is cold, it sounds like that might be the problem. IT could be a list of other things, but thats what it sounds like to me. Sometimes when a pilot bearing is about to go out, it will so it. That is usually the culprit. However, being new to the FD's, i have no clue if they even have a pilot bearing.
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
