cable mixup
Old May 16, 2002 | 09:58 PM
1Bad85Rex's Avatar
cable mixup
I cant tell which of the battery cables is which. The only distinguishable difference is that one has a little arrow on it and the other doesn't. Help! I do not want to fry my fusible links. Could someone check their car and let me know which is which?
Old May 16, 2002 | 10:01 PM
jeremy's Avatar
male stripper
the one that goes down to mount to the side of the shock tower and then on to the motor is the negative.
Old May 16, 2002 | 10:07 PM
1Bad85Rex's Avatar
good deal
Old May 17, 2002 | 04:30 PM
SuperPhly's Avatar
simple enuff
Old May 17, 2002 | 06:25 PM
crankit's Avatar
If you can't figure out which cable is which let someone else work on your car you probably be better off.
Old May 17, 2002 | 08:51 PM
yayarx7's Avatar
Are you Nucking Futs?
Hey now, the man has to learn sometime, now is as good as any, and there is no better teacher than making mistakes.
Old May 17, 2002 | 09:39 PM
79+80_rx-7's Avatar
doesnt the positive cable also have another wire goin to the fusiable links???
LATERZ, Andrew
Old May 18, 2002 | 02:37 PM
yayarx7's Avatar
Yep.
TeamRuffRacing
Sep 30, 2015 08:13 PM
rattlehead
Sep 25, 2015 10:55 PM
