rpm gauge wackyness
Old May 16, 2002 | 09:39 PM
lzyassmofo's Avatar
Unhappy rpm gauge wackyness
hey i just got my 93' r1 out of the body shop today. it hasnt been run in probably 5-6 weeks and the RPM gauge is not reading out accurately. Im wondering if the car just needs to be driven a bit or if i should take the dash apart and reset it. also any tips for turbo timer installations are welcome. thanks guys.
Old May 16, 2002 | 09:45 PM
user 84205's Avatar
how do you know its not accurate?
more info on turbo timer. What exactly do you
need to know?
Old May 16, 2002 | 09:53 PM
lzyassmofo's Avatar
well its reading out like 5-7 thousand rpms at idle and the engine clearly isnt high like that, audibly everything else is funtioning normally, and my boost is accurate.
Old May 16, 2002 | 10:49 PM
Pumped's Avatar
I have sort of the same problem, the tach needle jumps around,
there was a post about this matter, the gauge cluster having cracked solder joints, a wire in the front getting cut into etc....
I haven't had time to fix it yet though...
rgordon1979
40
Mar 15, 2022 12:04 PM
vmerino
Sep 5, 2015 11:26 AM
gabescanlon
Sep 5, 2015 12:09 AM
