Wiring harness R&R tips?
Old May 16, 2002 | 08:29 PM
P'cola FD's Avatar
Hamado things my way!
I'm in the process of replacing the main engine wiring harness, as well as the ignition harness that hooks to the battery. I finished off the night with the wires disconnected from everything, but still passing through the firewall. I have the ABS heatshield off and the ABS unbolted, but the harness is being a real bear to come out.
For those of you who have done this before: What is the best way to get the harness through the firewall? I'm sure I can figure out a way, but I figure I'd save the trouble and ask the pro's. Any tips are welcome. Thanks
Old May 16, 2002 | 10:28 PM
P'cola FD's Avatar
Anybody?
Old May 16, 2002 | 10:40 PM
Brad's Avatar
dear baby jesus...
hell, I just pulled on it until the rubber grommet came unseated from the hole...
Old May 16, 2002 | 10:44 PM
P'cola FD's Avatar
I have the grommet out, it's the wires that are being stubborn. Do I need to take anything out from the inside of the car(other than the obvious)?
Old May 16, 2002 | 11:01 PM
luneytune's Avatar
Cool
Make sure the upper connections, way up under the dash are free and you may have to turn them to get them to come through the hole. It's good to have help but don't rip the inside guy's hands off when it goes.
Old May 16, 2002 | 11:04 PM
P'cola FD's Avatar
Thanks luneytune. Anybody else?
Old May 17, 2002 | 01:13 PM
spyfish007's Avatar
Yellow Dragon is no more
It is easier to come from both sides. I always start by pushing it out from inside the car. Then I pull the slack out from the engine bay and then I go inside the car and start aligning the connectors so I can sort of push them out. Finally pull completely out from the engine bay.
Old May 17, 2002 | 10:20 PM
P'cola FD's Avatar
Got it out and the new one almost all the way back in today. The reason I was having so much trouble was because, from the inside, I was looking at the wrong set of wires, and overlooked the little metal cover over the harness. Once I took off the two 10mm nuts holding it down, the harness came out like butter (or "I can't believe it's not butter, for you healthy folk).
Ryan, good idea. I never thought of wrapping it. Thanks guys.
Old May 20, 2002 | 10:31 PM
P'cola FD's Avatar
Got the new harness in today, and my problems seem to be fixed. The car runs smooth and happy with the exception of a few minor quirks.
One more tip: When pulling the wires back through the firewall, spray some silicone lubricant on the grommet to get it in place easier.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
