need help...
Old May 16, 2002 | 07:20 PM
RX-7 GT's Avatar
HyperREV.com
need help...
ok, i finally got all the parts to piece my car together, however when i sold my old wiring harness i accidentally left some of the sensors/relays attached to it..DUH!
the ones im talkin about are near the ecu area, behind the plastic kick panel in the pass side. i.e. the atmospheric pressure sensor, knock control unit etc.
ok well i have the knock control unit, the pressure sensor, and the control fan unit. what else is left? im pretty sure im missing either 1 or 2, cause i remember more little boxes in that area?
thankyou,
brandon
Old May 17, 2002 | 02:42 AM
RX-7 GT's Avatar
HyperREV.com
please help
Old May 17, 2002 | 10:13 AM
Josepi's Avatar
Despise Enmity
Check the FSM?
Old May 17, 2002 | 01:29 PM
RX-7 GT's Avatar
HyperREV.com
it only identifies some...the ones i have
Old May 17, 2002 | 03:17 PM
Silkworm's Avatar
Has been.. hangin' around
A - identify your car.
B - The back of the FSM, in the wiring diagrams section, on the very back of that section, has a diagram of the entire front harness. Tracing the connectors on your harness and matching those to the front harness diagram should tell you which ones you don't have.
HTH, but as I recall, most of those connectors were to HVAC controls, audio stuff, and the things you've already mentioned. On my racecar, the only only connector I have left, aside from the Engine harness connectors, is the atmospheric pressure sensor. Sorry :\
PaulC
Old May 17, 2002 | 03:44 PM
RX-7 GT's Avatar
HyperREV.com
hmm...i will look again. its a 87 t2.
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
pjr
13
Sep 3, 2015 11:44 AM
damon
Aug 8, 2002 01:52 PM
ddr10
14
Jul 12, 2002 09:40 AM
autocrash
May 1, 2002 07:59 AM
