Haltech Car died now it wont start
Old Nov 30, 2008 | 02:08 PM
jamie k's Avatar
IN Car died now it wont start
i am only getting a 120 rpm reading on the data page. and the car died a few times while driving last week but refired just just a few seconds later. I am just needing a few ideas because its cold an raining an my garage is full. This is a e6a running 3 6al's.
Old Nov 30, 2008 | 05:09 PM
jamie k's Avatar
IN
ok. I charged the battery. pulled L1 an the cas spun the cas by hand and it has spark. but still no start... but rpms up to 180
Old Dec 3, 2008 | 07:47 PM
jamie k's Avatar
ok no fuel. anyone ..... anyone.....
Old Dec 3, 2008 | 07:57 PM
impactwrench's Avatar
Is this a Haltech? Could be similar problem I had with my microtech. The fuel pump circuit fried. Rather than send the ECU back to Austrailia, I ran a new, toggle switched line directly from the battery to the fuel pump. Cured.........
Old Dec 3, 2008 | 08:45 PM
jamie k's Avatar
yes its a haltech..... but i have fuel pressure 40psi
Old Dec 4, 2008 | 09:11 PM
polito Racing's Avatar
so you got pistons oh wow
hey man I have the same setup you have but with a e6s. I dont know if this helps but I dont see spark until it goes pass 250-300 RPM's make sure your battery and starter are good. 180 RPMs are to low. If the car is dying on the road also take a look at your alternator. they tend to go when youre running 3 msds!!! trust me I know!!! good luck. pm me if you need any other help
Old Dec 7, 2008 | 09:49 PM
jamie k's Avatar
i ran a few more checks an found that my alt. was grounding out. but when i spun the cas with the alt unpluged the injectors fired. pluged it back in they did not fire. someone explain that one....
Old Dec 11, 2008 | 08:28 PM
rx72c's Avatar
Top Answer: 1
Alternator must be dead. so everytime you connect it it shorts the system out.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
torky007
Aug 17, 2015 05:14 PM
