19x10.5 + 55 ??
Old Nov 30, 2008 | 12:49 AM
93FDADR's Avatar
19x10.5 + 55 ??
I am getting conflicting results searching as to if that should fit properly on an FD in the rear with a mild drop??
Old Nov 30, 2008 | 09:38 AM
purerx7's Avatar
Registered User
Well according to jimlabs worksheet, you wont clear the inside by .41 inches. This could be taken care of with coilovers. Should clear with minor work, or you could run a 5mm offset to clear the inside and do a mini roll with the fender. Depends what size tire you run too.
Old Nov 30, 2008 | 11:10 AM
93FDADR's Avatar
so say i run a 275/30/19. If i run a 5mm spacer out back and roll the fenders a bit, it should be ok?
Old Nov 30, 2008 | 11:18 AM
bewtew's Avatar
1BAD20B
that should work.
Old Nov 30, 2008 | 11:43 AM
purerx7's Avatar
Registered User
yep, should be fine, might not even need a roll.
Old Nov 30, 2008 | 11:57 AM
93FDADR's Avatar
alright, not i just gotta decided if i wanna sacrafice the lip using a +55 or keep searching for something with a bit less offset
Old Nov 30, 2008 | 12:27 PM
bewtew's Avatar
1BAD20B
i run 10.5 with a +43 of set and 275 30 19 in the back and no rub no fender roll i do have coilovers though
Old Nov 30, 2008 | 02:39 PM
purerx7's Avatar
Registered User
with a 10.5 wheel you will still have a decent size lip, depending on the wheel.
Do you have pictures from the rear of the car? I would be interested to see how flush that sits.
Old Nov 30, 2008 | 02:49 PM
bewtew's Avatar
1BAD20B
no i dont at the moment but i can take some pics tomorrow. the rims stick out a bit but since i run 275/30 on a 10.5 rim with coilover it fits perfect with no rubbing. ill try to take pics tomorrow i got some nice brand new ssr comp-h wheels
19x9.5 +45 and 19x10.5 +43
i only used them once no scratches, no curb rash. brand new!
Old Nov 30, 2008 | 04:17 PM
93FDADR's Avatar
I was looking at SSR professors . I am waiting to hear back from someone who has a set for sale currently on a supra. I guess if the price is right, ill go for em and use the 5mm spacer. Thanks for all the information
