Oil pressure sender/sensor on an fb
Old Nov 29, 2008 | 03:03 PM
fivehunsky's Avatar
So.. this is a stupid question but I have searched and couldnt find anything.. except fd owners talking about how theirs always fails.. haha
I just got this car and the wiring under the hood looks like a retarded blind chipmunk tried to "improve" the harness..
I figured out where the water temp sensor is and which wire it was.. Ive also figured out which wire controls the oil pressure gauge..
But where does it plug in at? Ive looked around the drivers side of the engine bay where the wire looks like it would naturally go.. but I cant find where to plug it in to.. I know the gauge works so Im hoping I can just plug it in and have a dash that completely works.. yay..
Any help would be appreciated..
Thanks in advance
Old Nov 29, 2008 | 08:00 PM
IanS's Avatar
Ricer
Oil press sensor is located directly next to (toward firewall) the water temp sensor on the drivers side. Its kinda hard to see it but its there.
Old Nov 29, 2008 | 10:47 PM
fivehunsky's Avatar
Cool.. thanks man.. I will go look again.. the engine was hot earlier so I couldnt really feel around that much..
Old Nov 29, 2008 | 11:05 PM
fivehunsky's Avatar
Hrrm.. is it on the actual engine? or the oil cooler? or what? I just went and looked/felt around again and I cant seem to find it..
Maybe Im missing the obvious? Do you have a pic for reference? I looked everywhere between the water temp sensor and the firewall and didnt see it.. maybe its broke off?
Old Nov 30, 2008 | 10:48 AM
Aaron Cake's Avatar
Engine, Not Motor
It's on the engine. It's directly below the oil filter. Looks like a mushroom.
But not every FB had an oil pressure sensor.
Old Nov 30, 2008 | 11:08 PM
fivehunsky's Avatar
Mine has an oil pressure gauge in the stock cluster so Im pretty sure its got a sensor somewhere.. I will go check it out in the morning.. Ive been busy with other stuff and kinda put it off..
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
