Which one is the AC RELAY ON? I want to run my fans all the time without the aircondi
Hey Bros, I was wondering how I can run my fans all the time without using the Air Conditioner, somebody suggested to remove the Ac Relay which side of engine bay is it on?, does that help to keep the fans running all the time? If not what other ways can I keep the fans running all the time, without using the Ac. I dont want to robb horsepower and burn alot of gas. I have noticed that with the fans running with the ac on, my water temp stays at 180F.
Or you can pull the A/C fuse. That way, you can control the radiator fans anytime by using the blower and A/C button. But the downside is that you wont have A/C anymore. And you'll get VERY HOT in the summer when driving.
If you go to my web page and check BILLION you will find another answer for your question. Im currently using the same thing. www.jt-imports.com
Jason
Jason
Re: Which one is the AC RELAY ON? I want to run my fans all the time without the aircondi
:The a/c relay is located in a relay box (about 9x2 inches rectangular) near the center front of the engine bay (vicinity between the headlights). I can't remember the exact stock location; mine sits below the ast and between the ast and ic duct (look in the picture in my sig to get a general idea). There's a schematic on the box showing you which relay is which; the a/c one is the second from the bottom.
Once you remove it, to run your fans, hit the a/c button and put your fan setting on 4 (high). The a/c compressor won't engage. Voila! Your own "fan mod" without actually running the a/c. Carry the relay in the car so you can switch back and forth as desired.
Any Questions?
Re: Re: Which one is the AC RELAY ON? I want to run my fans all the time without the aircondi
Thanks my brothers, what could i do with out you boyz, your the best!!!!!!!!!!!!!!1
So its the relay box on the left side of the engine bay right? right behined the left side headlight?
I removed the AC fuse from the rectangular box, so now when i press the AC Button and set the fan to 4 I can speed the fans and keep them running without the Ac correct? so now I wont be losing horsepower and gasoline right?
Trending Topics
On the box it has a bunch of little squares with the following information:
radio relay
Tns relay
(retra relay)
air cond relay
fuel pump relay
Go look under the hood homeskillet! Can't miss it!
I pulled it out and it works!!!!!!! when i turn the ac switch and set the fan on 4 as the speed it speeds the fans full blast, but now I wont be sacrificing horsepower and fuel consumption right?
!All bow down to the Master of the Indestructible Apex Seal
Wow, I really need a
1JZ powered
I am the Motherfucking Man
1JZ powered
Originally posted by AngeloRx7
what happens {good or bad} if you pull the 15 amp a/c fuse from the fusebox by the battery?
1JZ powered
1JZ powered
I pulled it, ... seems to shut my airpump off,
am I right?
am I right?
Originally posted by spyfish007
You are kidding right? Master of blowing 5 of 6 apex seals is more like it. You blow apex seals and I blow turbos and eccentric shafts. GET IT RIGHT! Oh yeah, you blow goats too.
2 questions for ya:
(1) When the hell are you coming back to Dallas?
(2) Do you mean "Tidal Wave" under your avatar, or is that some inside joke
--Rich
has blown a few apex seals in his day
Engine Management Forum
11
Nov 9, 2015 01:15 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
