coolant level sensor HELP!
Old Nov 28, 2008 | 08:55 PM
84gs_rx's Avatar
i was undoing the coolant level sensor when i was taking out my radiator and didnt undo the bullet connector. The wire broke right at the "bolt" of the sensor, not even enough left to sawder, does anyone know if a new sensor would come with some wire attached to connect back into the bullet connector????
-thanks noel
Old Nov 28, 2008 | 10:38 PM
IanS's Avatar
Ricer
I think Mazdatrix has them
Old Nov 28, 2008 | 11:02 PM
misterstyx69's Avatar
Retired Moderator, RIP
Yes it will,and If you are Frugal(cheap) you can find one used in the Ever faithful Sec Gen Parts section.(sender is compatible for 1st and 2nd Gens).
Old Nov 29, 2008 | 10:33 PM
84gs_rx's Avatar
thanks guys.....appricate it. i found them on mazdatrix but i think ima see what the dealer is asking, see if i can get it in sooner and be back behind the wheel of the rex im getting withdrawls haha.
Old Dec 4, 2008 | 04:07 PM
Kristin's Avatar
Newbie
The same thing happened to mine- Annoying sound. haha.
I ghetto rigged a wire into where the sensor connects and clipped it to some metal- it grounds it and stops the noise but it obviously doesn't sense coolant level anymore, so I check the coolant all the time, and I definetly need a new part-- But I have to drive the car, so it had to be done.
JoesFC
Oct 5, 2015 08:10 AM
rotary_rx7fc
20
Sep 19, 2015 02:41 PM
