GT42R VS hks t51r
Old Nov 26, 2008 | 09:09 PM
darkphantom's Avatar
The king of the highway!
GT42R VS hks t51r
JUST WONDERING which one is bigger than the other. between the GT42 & the HKS T51r
Old Nov 26, 2008 | 10:51 PM
Havoc's Avatar
In pure size I believe the GT42 is.
Old Nov 26, 2008 | 11:45 PM
dregg100's Avatar
which t51? kai or spl? just get the garrett or borg unit and save yourself some money
Old Nov 27, 2008 | 12:05 AM
i like the way the t51 sounds
Old Nov 27, 2008 | 02:39 AM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Buying a turbo because of the way it "sounds" is recockulous.... Damn inter-webz is full of tards I tell ya.
Oh, and on the original question, why the hell don't you just SEARCH for it.....Besides the fact it's a no brainer.
-J
Old Nov 27, 2008 | 12:03 PM
arghx's Avatar
rotorhead
I was under the impression that the SPL was bigger actually
Old Nov 27, 2008 | 12:13 PM
classicauto's Avatar
Crash Auto?Fix Auto.
An anti-surge compressor cover will make a similar whistling sound, though the HKS unit has a very small spacing which probably makes the noise higher pitched then a garrett standard anti-surge.
But nonetheless, you can get that sound without the HK$ price tag.
Old Nov 27, 2008 | 03:06 PM
yeah the spl is actually bigger. YOU be suprised how close in size each turbo is but the kai is more closer to the gt42r than the spl. but the 42 is a bigger turbo i know that for a fact. but the question is how big is it from the T51. & ive searched before. it seemes no one wants to pay HKS money thus why not alot of people have the turbo!
Old Nov 27, 2008 | 06:08 PM
dregg100's Avatar
thats because it is a waste of money. yes the spl is the bigger, closer to gt45 in size.
Old Nov 27, 2008 | 09:54 PM
not from this map
http://www.turbobricks.com/resources...tent=turbodata
btw its been proved that 700hp is possible under 28lbs on a t51r. just not here in the states! (scoot 710hp rx7 @ 2.0 bar)
Old Nov 28, 2008 | 12:44 AM
Havoc's Avatar
mate do you want the physical size difference or just the wheel size ?
Big thread here should help you out.
http://www.ausrotary.com/viewtopic.p...gt42&start=180
Old Nov 28, 2008 | 01:01 AM
crispeed's Avatar
'Tuna'
not from this map
Just like every car that dyno in japan always do a lot less here. Wonder why? It's called correction factor. Every type of dyno is different.
Old Nov 28, 2008 | 01:38 AM
OZZYINCALI's Avatar
CA hks far superior
t51r is based of a garret ta45s which I think you can still buy from garret The t51r's have a higher flow rating than the ta45s but similar spool and response times! The hks units have better flowing compressor housings with a slot around the inlet that feeds air into the sides of the inducer to reduce compressor surge! also the hks turbos feature the bullet shaped compressor nut that is said to also improve flow. thanks for listening
Old Nov 28, 2008 | 01:46 AM
OZZYINCALI's Avatar
CA hks compressor sizes
t51r'kai' inducer is 70.3mm 'spl' 76.5 both have a 1.0a/r exhaust housing. both avilable in ball and plain bearing. trust turbos are worth a mention too.
Old Nov 28, 2008 | 06:31 PM
yeah but it shouldnt be that much different from one dyno to another overseas when it comes to there cars!
im refering to the actual size difference!
Old Nov 29, 2008 | 05:20 AM
K_1_M's Avatar
The Garett gt4202r with the tial housing is pretty much the exact same size as the HKS t51r SPL... With the t4 and t6 frame the garett is bigger.
But why do you need to know the size? Wondering what box to put it in??
Old Nov 29, 2008 | 12:02 PM
OZZYINCALI's Avatar
CA
My thought exactly what are you looking for? big or efficient?
Old Mar 16, 2013 | 09:56 AM
Clyton91's Avatar
Hey guys
Does anyone have a compressor map for a GT4502r?
Thanks in advance!
Old Mar 16, 2013 | 12:07 PM
Havoc's Avatar
Originally Posted by Clyton91
Hey guys
Thanks in advance!
umm.. just go to the manufacturers web site.
Old Apr 1, 2013 | 08:19 AM
nice to see my thread resurected from 5 yrs ago even though i did go with the GT42....... wierd to see that half comments are making fun of Newbies & other half actually help you out...
either way i went with the GT42 since the T51 is same size but for the sound is ridicilous.... besides the fact the GT42 outflows more.... & i made a hybrid by Machining a GT45 wheel in the 42R.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
