removal of the sound denter inside
Old Nov 26, 2008 | 09:25 AM
2NDGENKID's Avatar
project 87 in making
how do you remove the sound denter on the floor of these rx7s. i got some off were water got under but the other parts are so hard to remove. thanks alot chris
Old Nov 26, 2008 | 05:58 PM
MyRedFD's Avatar
Enter Title Here
Do you mean the padding under the carpet? It's glued down so you'll have to peel it off, carefully if you want to reuse it.
Old Nov 26, 2008 | 07:16 PM
r/t_turbo2's Avatar
dry ice works great
Old Nov 27, 2008 | 04:01 PM
2NDGENKID's Avatar
anyone ever use heat. maybe a heat gun or torch? were can you by dry ice? and how does that work? thanks chris
not planning on using it again.
Old Dec 3, 2008 | 11:58 PM
LeeC's Avatar
No Exhaust Leak
I have always used a heat gun, a PLASTIC or RUBBER scraper, not metal, to get 99% of it off, then while it's still hot use engine degreaser and a rag to wipe away any residue
ZacMan
Sep 19, 2015 09:20 PM
risingsunroof82
Sep 7, 2015 01:11 PM
83revival
Sep 3, 2015 10:42 PM
tiger18
Sep 3, 2015 08:27 PM
