? about temp gauge
Old Nov 24, 2008 | 11:53 PM
DREWZ R2's Avatar
CA ? about temp gauge
does anyone disagree in installing the after market water temp gauge sensor to the stock sensor. i understand this will eliminate the stock gauge. but other than that does anyone kno if it gives an accurate reading or should i just tap.
Old Nov 24, 2008 | 11:57 PM
mar3's Avatar
Administrator
Good question...I've always used the sensor supplied with any aftermarket gauge I've ever bought so I wouldn't personally know. Anyone else...?
Mario III
Old Nov 25, 2008 | 12:23 AM
rowtareh?'s Avatar
I Dislike Everything
What model? FB, FC, FD?
Considering the age of these vehicles and how much automotive technology has changed, it's not a bad idea to use the sensor in the aftermarket gauge.
Old Nov 25, 2008 | 03:58 AM
ThoRx7's Avatar
i did it on my fd because i read somewhere on this forum that the temp is inaccurate.
Old Nov 25, 2008 | 04:53 AM
dgeesaman's Avatar
If it's an FD, I see two options:
1) Install an aftermarket gauge and use the sensor that comes with it (note: I used an existing tap on my water pump housing and did not need to cut into mine)
2) Linearize the stock gauge and skip having an extra gauge.
Dave
Old Nov 25, 2008 | 08:43 PM
DREWZ R2's Avatar
Its a FD. i purchased the greddy boost and temp gauge i kinda just want to be prepared when i install it and i started to read some installs one the forum and seen the optiion of using the stock oil temp sensor.
Old Nov 25, 2008 | 08:44 PM
dgeesaman's Avatar
See how I did it on www.davidgeesaman.com
Old Nov 25, 2008 | 08:45 PM
DREWZ R2's Avatar
CA
to use the tap on the water pump housing, do i need anything in order to do that. or does everything i need come with the after market gauge.(52mm greddy temp gauge)
Old Nov 25, 2008 | 10:25 PM
DREWZ R2's Avatar
thanks dave.
Old Nov 27, 2008 | 02:42 PM
trochoid's Avatar
Old Fart Young at Heart
When I rebuilt the engine in my 1st gen, I retapped the stock sender location to accept an aftermarket sender. Upon telling a friend that this is the best location to get the 'ideal' temp reading, he retapped the stock location on his engine while it was still in the car. He used bearing grease on his fresh/sharp tap to catch the shavings and had no problems.
On 1st/2nd gen engines, I usually recommend drilling and tapping the land on the backside of the waterpump housing, right next to the oem #2 temp sender. Not sure if that can be done on the 3rd waterpump housings or not, never work on them.
Old Nov 29, 2008 | 02:48 PM
Rdodds033's Avatar
i dont know if any of you have a apex-i power FC. if you dont you might as well kill yourself for not having one! anyway if you do you dont need a aftermarket temp gauge. just mount your commander (if you have one) up where you can see it and it will show you the water temp, or various other data (in a graph or just the digital read out). the power FC is the best tool you will ever have for you FD PERIOD.
The1Sun
Sep 15, 2015 04:45 PM
Monsterbox
Sep 11, 2015 03:29 PM
vmerino
Sep 5, 2015 11:26 AM
