Woot no more broken radio surround!
Old Nov 24, 2008 | 08:44 PM
celbii's Avatar
jackie chan > chuck norri
Just got my new radio mount kit and my s5 surround and vents and put it all together. I don't know if the old s5 are like these brand new surrounds but this thing is tighter than ****. I literally had to put a ton of pressure on all the parts just to get them to fit into the surround. Looks nice though compared to an old broken messed up s4 one.
Old Nov 24, 2008 | 10:00 PM
FC3SDKJones's Avatar
Wow that is really clean. So you can swap S4 and S5 surrounds? Where did you get that one?
Old Nov 24, 2008 | 10:20 PM
ArtOfRuin's Avatar
RotorDork
Yes, you can replace an S4 surround with an S5 surround, but you need S5 upper vents and an S5 shift boot panel also. The S5 surround is way more durable than the S4 surround. I'm looking for one to replace (what's left of) my S4's surround.
Old Nov 24, 2008 | 10:54 PM
celbii's Avatar
Im using the s4 shifter surround its a little differnt but no big deal to me. I got the parts from the mazda dealer I have a friend who works there so I got a discount ended up around 140 for the surround and vents. I thinking its about 200 normally.
Old Nov 24, 2008 | 11:03 PM
87 t-66's Avatar
not a drifter
i am also using the s4 shifter surround with the s5 upper surround. fits fine.
Old Nov 24, 2008 | 11:37 PM
celbii's Avatar
Yeah you can pretty much tell what it looks like from my pic. The old s4 stuff is more a gloss black and if you look at the second picture you can see how it lines up slightly off because the s5 is wider i think. But it hardly matters and its way better than a broken s4. So you can tell all the people going around on the fourms saying you cant use s4 shifter with s5 surround to check this thread.
Edit:god my ashtry is so nasty greenish color lol.
Old Nov 25, 2008 | 12:29 AM
Boosted11's Avatar
Pistons are gay
That looks sweet man. I have a perfect condition s4 surround, but the s5 looks alot more appealing.
Old Nov 25, 2008 | 12:33 AM
celbii's Avatar
I had a perfect s4 surround a year ago when i got the car, but then i took out the non working stock stereo and it fell apart lol.
Old Nov 25, 2008 | 01:43 PM
francogt1's Avatar
Lots of Hope
I have the same setup except different headUnit. Fits very well.
Old Nov 25, 2008 | 03:40 PM
CyborgRyu's Avatar
Drift FC
I drive an S5, it comes standard.
Old Nov 25, 2008 | 03:45 PM
cmanns's Avatar
Smoke moar
What radio kit did you use?
I lost the original brackets
Old Nov 25, 2008 | 04:39 PM
ArtOfRuin's Avatar
RotorDork
Oh, I was under the impression you need the S5 shifter surround to work with the S5 stereo surround. I don't have a stereo surround or shifter surround in my car right now. Maybe that's why I thought that.
Old Nov 26, 2008 | 12:08 AM
celbii's Avatar
I bought this kit. http://www.crutchfield.com/p_1209975...sh+kit&tp=3121
The main problem is with s4's you have to use the spacers which i broke the first time i think, but i also had a already messed up surround by then so if your careful on a s4 you should be okay. The s5 doesnt need the spacers in the kit so the kit is alot easier to install.
Old Nov 26, 2008 | 12:30 AM
ecko's Avatar
E85 Powered
wow one clean interior.
Old Nov 26, 2008 | 02:07 AM
DavidHolmesIII's Avatar
Marvelous Hedonist
Before pics would have painted a brighter picture. . . clean though.
I did the same switch a while back. However I did not get the S5 vents, which I regret. I'll get to it sooner or later. . . until then I will just have to deal with the gaping hole similar to that in which you posted in your first picture.
Old Nov 26, 2008 | 09:14 AM
RxFuel's Avatar
Ten cents gets ya nutz!
pretty good lookin little upgrade, might have to go this way also since mine too fell apart when I took it off.
Old Nov 26, 2008 | 01:33 PM
celbii's Avatar
Cant find any pics of it broken on the car, but this is what it looks like now, and i cut up the bottom part to get the cig lighter out.
Old Nov 26, 2008 | 02:32 PM
MaczPayne's Avatar
Mac Attack
S4 surrounds are quite durable when they are brand new.
Old Nov 26, 2008 | 03:26 PM
stylEmon's Avatar
FC since 99
S5 are quite MORE durable when new :P
Old Nov 29, 2008 | 04:13 PM
celbii's Avatar
Yeah, i was surprised at how durable that thing was compared to my s4 stuff, it was more than night and day difference lol.
Old Dec 2, 2008 | 09:01 AM
cmanns's Avatar
Smoke moar
Does it replace the stock mounting hardware good?I got a s5 btw
Old Dec 3, 2008 | 06:12 PM
EPD's Avatar
EPD
if i remember the s4 is molded plastic and the s5 is a metal frame with a rubberized type of coating on it. I dig the s5 over the s4 any day, if you look at the s4 wrong it will break.
Old Dec 3, 2008 | 06:45 PM
celbii's Avatar
Yep If you get a aftermarket radio all you need is that kit, and it has 3 differnt mounting styles also depending what type of radio you buy. You just use your stock screws to screw the radio bracket you make from that kit in then you put the surround on then the radio.
Unless you smart like me and already get the surround and forget to screw in the radio kit and already plugged the cig lighter back in so its a pain in the *** to get everything out, That made it real fun screwing them in. I also made sure to put in about half way and hook it up and stuff before pushing it in all the way and putting in the bottom pocket peice.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
