Power FC Timing Logs Off
Old Nov 22, 2008 | 10:39 PM
207's Avatar
207
Timing Logs Off
I have searched but no real answer....
My basic, and advanced, timing logs are 4 to 5 degs below the timing in the map from about 5psi boost and above.
Which timing should I trust, the map or the log?
And why might this be happening?
Old Nov 22, 2008 | 11:02 PM
cewrx7r1's Avatar
Eye In The Sky
First thing! If you Settings 3 Map Referenece Boost and RPMs are not the same as the map that is used while looking at Map Watch, then the displayed data will be in the wrong cells.
Second thing! Use a Map Watch Hold off (mSec) of at lease 20 to pick data that is more centered in the cell.
Old Nov 23, 2008 | 08:33 AM
207's Avatar
207
I have the Settings Map Ref. setup for the 3 bar GM, which I "ASSUME" is the same as the Map Watch. Did I miss something in setting up the Map Watch
I'm holding 10 picks, but I will raise it to 20.
Old Nov 24, 2008 | 06:31 AM
207's Avatar
207
I have the Settings Map Ref. setup for the 3 bar GM, which I "ASSUME" will set the map for the the Map Watch the same. Did I miss something in setting up the Map Watch?
Old Nov 24, 2008 | 10:32 PM
cewrx7r1's Avatar
Eye In The Sky
Only when viewing Map Watch with MAP REF of ADVANCE does the loaded map have to be your map as stated above.
Old Nov 24, 2008 | 11:28 PM
arghx's Avatar
rotorhead
When tracing timing and AFR curves I go back into the charts and follow the lines with the slider bar thingie. I set up my watches and look at that for actual numbers. If you use the ghost and map trace feature it will give you an idea of what cells you are falling in to.
Once you get the hang of adjusting the timescale it can sometimes be more accurate than map watch because you need to constantly fiddle with the mapwatch holdoff settings.
Make sure you go into the Setup menu and set the source to "Advance" or "Map Ref," whichever you prefer, and then go into Map watch options menu and set it to the same setting.
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
dkwasherexd
May 27, 2017 04:51 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
sYnth.
Aug 19, 2015 06:27 PM
